Go to Post Hearing about the beginnings of 842 was truly inspirational and has really stuck with me through the years. After following you guys for so long it was crazy for me to play with you. Thank you for all that you have done for FIRST in Arizona. - Saberbot [more]
Unread 26-02-2004, 11:39
Ryan Cumings's Avatar
Ryan Cumings Ryan Cumings is offline
Programmer and University Rejected
#0134 (Team Discovery)
Ryan Cumings is an unknown quantity at this point
Send a message via AIM to Ryan Cumings
EEPROM + Backup Battery
Does the EEPROM require the backup battery to be present inorder to work properly?
Suddenly being rejected from college feels right during the build season. Now I am a mentor.
Unread 26-02-2004, 13:37
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: EEPROM + Backup Battery
Don't know. I know that it doesn't need it to maintain it, like flash memory. Why?
Unread 26-02-2004, 13:56
Random Dude Random Dude is offline
Oregon State Head FTA
AKA: Chris
no team (Oregon Robotics Tournament & Outreach Program)
Random Dude will become famous soon enoughRandom Dude will become famous soon enough
Nope, it works just fine with out it.
Unread 28-02-2004, 13:22
Dinush Dinush is offline
Build Team!!
AKA: Dina Begun
#0912 (Iron Lyons)
Team Role: Student
Dinush is an unknown quantity at this point
Send a message via ICQ to Dinush Send a message via MSN to Dinush
The backup battery is necessary in case there is a power overload so that the microcontroller doesn't reset. It is also used to power the pwms (or at the very least the pwms don't produce the necessary voltage without it plugged in, so therefore anything connected to the pwm wouldn't work properly.
--> 2003: Winners of Canadian Regional. Thanks 1088 and 378!
Unread 28-02-2004, 13:30
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
That is not 100% correct. The backup battery when connected powers one of the pins on the pwm chain which is needed to run the servoes. Anything other then servoes will run fine on the pwm's without the backup battery.
-Michael Dessingue
charging backup battery Max Lobovsky Electrical 6 12-03-2004 10:24
Urgent!!! Problem concerning Backup battery and autonomous. Code\\Pilot Programming 3 26-02-2004 16:44
Cutting wire on backup battery MikeDubreuil Electrical 4 23-02-2004 18:55
buy extra backup battery MaxM Electrical 2 20-02-2004 18:11
Weight of Backup Battery? sanddrag Control System 0 16-02-2004 20:58
