Go to Post It would be a (relatively) level* playing field *...though it seems like the actual field will be anything but level. - Jacob Bendicksen [more]
Unread 23-02-2002, 16:55
Jon Lawton Jon Lawton is offline
Bitter FIRST Cynic
Jon Lawton is an unknown quantity at this point
Send a message via ICQ to Jon Lawton Send a message via AIM to Jon Lawton
This year's battery is 12V at 18Ah, the charger is somwhere about 14V at 1A.
Last year's battery is 12V at 17.5Ah, the charger is some voltage I don't know off the top of my head, at 4A.
So... assuming the charging is 100% efficent (HAH!):
18A at 1A/hour = 18 hours
17.5A at 4A/hour = 4.375 hours
Remember though, these values are for a *totally* dead battery (and they are a little small, I can gaurentee that it won't charge at 100% efficency)!
I'd reccomend charging your batteries up all of the way, and putting some kind of ammeter on your robot and charger. This way you can have a pretty good idea of the charge state of the battery.
Why did FIRST give us this *WIMPY* charger this year? Why do they care what we use to put energy back into the battery? This, I think, is most uncool.
Unread 26-02-2002, 19:02
Matt Reiland's Avatar
'The' drive behind the drive
Were bringing last years chargers anyway, I can't see why if they were legal last year they wouldn't be this year, besides we now have four of them from over the years. I like the fact that the new one is small but our robot eats monster current this year and normally puts the low battery LED on after about 5 minutes tops.
Unread 02-03-2002, 11:08
RicNic_team930's Avatar
RicNic_team930 RicNic_team930 is offline
#0930 (m cubed)
RicNic_team930 is an unknown quantity at this point
Send a message via AIM to RicNic_team930
Unhappy
I'm on a rookie team. We don't have anything from last year to use. or extra money (were going to nationals) 1 battery lasted for about 3 4 hours of testing and a full batery lasted more than 2 hours of continous compition we did with other WI teams so i dont see why 2 fully charged batteries won't last for a day.
ricnic
Unread 02-03-2002, 14:46
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
*Not on control systems. I understand the concept*
It all depents on the load you are pulling. A bot with a 6 moter drivetrain will pull more than a 2 moter drivetrain. And if you spend all match in a tug-of-war, driving the moters near stall vs a ball getter where you are not running the moters so hard.
And if you are running the bot around alot, take breaks to protect to moters.
Hmm...
As I think about this, what if this was intended as an equalizer this year but no one noticed?
Viva Olancho!
Unread 03-03-2002, 01:07
Tom Fairchild's Avatar
Tom Fairchild Tom Fairchild is offline
Nice Guy
Tom Fairchild will become famous soon enoughTom Fairchild will become famous soon enough
Send a message via AIM to Tom Fairchild
I can tell you that the LED light that tells you if your battery is low is not really to be trusted. It turns on when the battery drops to a certain voltage and it doesn't matter if it stays there or not. Our robot you can drive for 30 sec. and the light will come on if you gas it full forward quickly. The thing to keep your eye on is the actual voltage on the control system display.
~Tom Fairchild~
Unread 09-03-2002, 21:44
To All,
I saw some disturbing reports here and I want to make sure everyone is on the same page.
To the team that is charging from dead to full in one hour, cease and desist. The internal heat from that kind of charge cannot escape or conduct to the outside quick enough for you to stop the charge when the battery gets warm. If you are able to full charge in an hour you are most likely charging at 18-20 amps. This amount of current if it doesn't blow the battery will surely damage internals. The kind of damage will show up when you least expect it, like out on the floor.
The specification from the battery maker is specified at 4 amps max. Last year's charger was a step charger and speced at 2 amps. At 2 amps, constant current charging, a dead battery should take about 8-10 hours to reach full charge. At 1 amp twice that length of time or 16-20 hours.
Good Luck All
Weigh in with or without battery Joe Clohessy Rules/Strategy 33 21-09-2003 20:31
Quick release battery connector and 120 amps n[ate]vw Electrical 6 18-01-2003 23:41
Off-topic battery stuff. FotoPlasma Electrical 4 06-01-2003 12:19
connecting to the battery ahecht Technical Discussion 1 25-01-2002 17:15
