Go to Post Blue shirts are ALWAYS watching. And they have spies everywhere. Always be on your best behavior, and be polite to every volunteer at the event. - Andrew Schreiber [more]
Unread 28-02-2004, 20:14
Pierson's Avatar
Pierson Pierson is offline
Pierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of light
Send a message via AIM to Pierson
Re: A bit of fun.. you might be an engineer if...
Originally Posted by KenWittlief
You are flying in a commercial aircraft, and the pilot announces 'we are now flying at 32,000 feet' - within a few minutes you calculate how far you can see on the horizon, and if you were to fall out of the plane at this alt, how long until you reach the ground.
I really need to do this... Better yet, it would be too much fun to start telling the passengers around you, "Well, if the plane were to disintegrate right now, you would hit the ground in x seconds."
Pierson
Former Captain & Fundraiser of Team 360
Join in on these fun threads:
Three Worded Story
Word Association
Unread 28-02-2004, 20:46
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
Remember to calculate the terminal velocity of your airplane too!
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 29-02-2004, 08:37
if you jump out of the plane and freefall your terminal velocity is about 200 mph, due to the wind resistance.
Unread 29-02-2004, 14:05
Yan Wang's Avatar
Ithaca is Gorges
AKA: John Wayne
Yes, if you are balled up... stick your arms and legs out and you cut it down to 125mph.
... not that you won't die anyway.
Extracting Individual bits in C Noah Programming 7 08-01-2004 15:53
Makin' a home-brewn dashboard program, and I need theory help! DanL Programming 33 05-07-2002 01:26
Thanks for the fun all... archiver 2001 0 24-06-2002 03:23
Just for fun. archiver 2000 7 24-06-2002 00:16
fun fun fun.... Brian Savitt Regional Competitions 0 31-05-2001 20:59
