Go to Post So please, think twice before you click that little button that says "reply". - Ken Leung [more]
Unread 24-02-2004, 08:55
Srkasner Srkasner is offline
Srkasner is an unknown quantity at this point
Question Globe motor backdrive!!
Our team is using a globe motor to use the mast system on our robot to pull the robot off the ground after attaching to the bar. It has enough torque to pull up but it back drives awfully! Has anyone come up with a way to stop the globe motors from back driving? Thanx!
~Steve
Team 1124
There are only 10 types of people in this world; Those who understand binary, and those who do not.
Unread 24-02-2004, 09:24
Joel Glidden's Avatar
Joel Glidden Joel Glidden is offline
My heart pumps diesel.
FRC #4293 (Komodo)
Joel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of light
Re: Globe motor backdrive!!
Have you tried simply putting that globe motor on a speed controler in brake mode? If that doesn't work, you'll have to design some form of locking mechanism. You could use a servo to insert a locking pin, or you could design a ratchet similar to this one.
-Joel
Unread 24-02-2004, 09:29
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Good advice. It is pretty easy to make a catch that only locks in when your robot is fully lifted. One down side is that once you are up, you are up. This is probably not a huge issue but your drivers will have to make sure they are not going to have to get down again.
Joe J.
Unread 28-02-2004, 20:34
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
Take a look at the gate latches at any hardware store, one of those was the cause of us nearly winning the vcu regional and getting into the finals at nationals our rookie year. Sometimes the simpleest solution is one of the best.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 28-02-2004, 20:52
Rich Kressly's Avatar
Rich Kressly Rich Kressly is offline
Robot/STEM troublemaker since 2001
no team (Formerly 103 & 1712. Now run U.P. Robotics (other programs))
Rich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond repute
We're using another motor to lift but have a brake that is applied to our tower at any elevation with a small pneumatic cylinder so we hang steady after the power is cut.
technology, innovation, and invention without a social conscience will only allow us to destroy ourselves in more creative ways
Unread 28-02-2004, 21:00
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
You can use a standard ratchet (like what you tighten bolts with) driven by your motor.
Unread 28-02-2004, 21:11
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
Another way I think you could do it would be to put a latching relay between the two leads on the motor, and have it off until you want the motor to lock then switch it to the on position. That will at least slow it down.
Unread 28-02-2004, 21:32
REVving up for a new season
FRC #2848 (All-sparks)
true but you have to beable to stop back drive after the power is shut off....i really think some of the mechanical soultions mentioned in this thread will help you out. i also was thinking of a wrap spring ( like inside your tape measure) around the shaft of your motor...since you know the total distance you will traven you can have it set to put pressure on in the forward direction of motor travel that way when if starts to backdrive the spring would be working in your favor.....
also if you use another mechanciacl method why don;t you activate it by a limit switch on your grabber that way when you are at the height you want it will automaticly trigger eliminating the back drive which would take place untill the trigger is activated
Unread 28-02-2004, 22:30
The big guy
While the relay thing might work for a hobbie robot their are a few issuses with using that system in FIRST.
The speed controllers can already be set to do this automatically see the section about the coast/brake jumper on IFI's site
Only speed controllers my be attached to the globe motor
and the relay wouldent stay latched after power was removed, all of our compeition legal relays arnt latching and cant legely be made so.
this isnt ment to down the idea, like I said its a good idea, and has uses however its illegeal for us.
Justin Stiltner
KI4URQ
Unread 28-02-2004, 22:56
jacob_dilles's Avatar
jacob_dilles jacob_dilles is offline
AKA: theshadow
FRC #0620 (WarBots)
jacob_dilles will become famous soon enough
Send a message via AIM to jacob_dilles
we have a simple sensor on our lift that once the "on bar" switch is fliped, if the button is not moved and the sensor sais that the lift is moving, to aply current in the opisot direction. this works at least till the bot is disabled. it is just a quick programing fix, but it works... im sure its tearable for the motors tho
"You're not a real programmer until all your sentences end with semicolons;"
Unread 29-02-2004, 02:24
KevinB's Avatar
KevinB KevinB is offline
AKA: Alum
Yea we have problems with Globe motor backdrive ... Setting the speed controller to break mode doesn't help.
What we did was use a pneumatic cylinder to engage a "lock" mechanism.
Unread 03-03-2004, 07:38
FadyS.'s Avatar
FadyS. FadyS. is offline
AKA: Fady Samuel
#1246 (Agincourt Robotics)
FadyS. is on a distinguished road
Hi, we're a rookie team and we're also experiencing backdrive on our Globes, since the robot has already been submitted we need to find a solution for this and fix it at the competition. Can anyone please provide me with a picture of this solution. Any help would be greatly appreciated because the Globes play a vital role in our bot because they operate the drum that raises and lowers the arms of our bot. Thanks in advance.
Unread 03-03-2004, 17:05
KevinB's Avatar
AKA: Alum
Is this arm used to hang the bot?
Or is this just an arm used for manipulation during the match itself?
Unread 03-03-2004, 18:13
FadyS.'s Avatar
AKA: Fady Samuel
The arm is used to hang the bot and to pick up the 2X ball.
EDIT: Hanging isn't the problem because we set stops at that point when the arms are pointing all the way up. It's picking up the 2X ball that we're having trouble with.
Unread 04-03-2004, 09:39
Greg McCoy's Avatar
Greg McCoy Greg McCoy is offline
boiler up!
FRC #3940 (CyberTooth)
Greg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond repute
Send a message via AIM to Greg McCoy
I think that setting our Globe motor Victors to brake did help keep our arm's wrist from "drooping" back down when the control was at neutral. There might not be enough "brake" for a robot-lifting application though...
Globe motor dimension drawing jskene Motors 0 15-02-2004 13:34
Globe Motor archiver 2000 4 24-06-2002 00:15
Globe Motor archiver 2000 0 24-06-2002 00:15
So you want to stall a Globe Motor... archiver 2000 1 24-06-2002 00:09
Globe Motors & other FIRST Suppliers at Design Show archiver 1999 2 23-06-2002 22:07
