Re: Clamping wheel hubs
from what it sounds like your bolting 2 plates on either side of a unkeyd wheel. is this right? because if that is what your saying, the bolts, and the friction of the 2 plates pressing ageinst the wheel would deffently be enugh to drive it.
sorry if i missed the point totaly |
How do you know it would be enough? Also, does surface area have anything to do with this? |
well if the bolts arent in direct contact...
it depends on a lot of things. first of all, the 2 surfaces. if there both plastic then its gonna take more force then steel to get them to stay. if you want it to be pure friction, its gonna be the more torque the better. roughing up one or both surfaces will reduce the amount of torque needed. genraly speaking, if your dealing with metal a half turn past hand tight should be okay for 1/4, a 3/4ths a turn past for 3/16. if its lexan or plexi, your gonna have to be realy torquin down, maybe 2 or 3 turns past hand tight. but friction can ALWASE slip, especialy if there is an eccesive (and usaly unplaned) force in a parrallell direction to the planes that the friction is acting on (sry a bit confusing). reinfocing with pop rivits or even 1 or 2 roll pins is never a bad idea. hope everything works out. |
The drive plates will be 3/16" thick aluminum and the wheel is polypropelyne plastic
| Need MMH wheel hubs, please! | tstearns | Kit & Additional Hardware | 0 | 17-02-2004 20:35 |
| how can you use a gyro in autonomous mode | magical hands | Programming | 3 | 02-01-2004 13:31 |
| plastic hubs and drill motors | Will Camisa | General Forum | 4 | 01-03-2003 00:03 |
| small parts wheel hubs | exser | General Forum | 1 | 22-01-2003 23:28 |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 29-01-2002 12:32 |
