Go to Post In the long run, you don't remember your ranking points, you remember the lessons and friendships from when you were on a robotics team in high school. - smurfgirl [more]
Unread 28-02-2004, 22:27
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Clamping wheel hubs
Originally Posted by jacob_dilles
from what it sounds like your bolting 2 plates on either side of a unkeyd wheel. is this right? because if that is what your saying, the bolts, and the friction of the 2 plates pressing ageinst the wheel would deffently be enugh to drive it.
sorry if i missed the point totaly
You actually totally got the point. The wheel would be unkeyed but the hubs would be keyed. The hubs would clamp the wheel. Don't think about the bolts going through the wheel to drive it (since that part is very thin plastic), think only about the friction of the clamping force of the two plates.
How do you know it would be enough?
Also, does surface area have anything to do with this?
Unread 28-02-2004, 22:34
jacob_dilles's Avatar
jacob_dilles jacob_dilles is offline
AKA: theshadow
FRC #0620 (WarBots)
jacob_dilles will become famous soon enough
Send a message via AIM to jacob_dilles
well if the bolts arent in direct contact...
it depends on a lot of things. first of all, the 2 surfaces. if there both plastic then its gonna take more force then steel to get them to stay. if you want it to be pure friction, its gonna be the more torque the better. roughing up one or both surfaces will reduce the amount of torque needed. genraly speaking, if your dealing with metal a half turn past hand tight should be okay for 1/4, a 3/4ths a turn past for 3/16. if its lexan or plexi, your gonna have to be realy torquin down, maybe 2 or 3 turns past hand tight.
but friction can ALWASE slip, especialy if there is an eccesive (and usaly unplaned) force in a parrallell direction to the planes that the friction is acting on (sry a bit confusing). reinfocing with pop rivits or even 1 or 2 roll pins is never a bad idea. hope everything works out.
"You're not a real programmer until all your sentences end with semicolons;"
Unread 28-02-2004, 22:38
The drive plates will be 3/16" thick aluminum and the wheel is polypropelyne plastic
Need MMH wheel hubs, please! tstearns Kit & Additional Hardware 0 17-02-2004 20:35
how can you use a gyro in autonomous mode magical hands Programming 3 02-01-2004 13:31
plastic hubs and drill motors Will Camisa General Forum 4 01-03-2003 00:03
small parts wheel hubs exser General Forum 1 22-01-2003 23:28
