Go to Post Don't ever give up on your robot, especially this early in the season. That robot is what you make of it. If you give it your all, something good is bound to come your way. - Amanda Morrison [more]
Unread 25-02-2004, 19:18
Programming port burning hot
We accidentally touched the programming port on the RC and it was burning hot. The robot had been on for about 15 minutes, but it wasn't moving or anything.
Has anyone else experienced this?
Unread 25-02-2004, 23:56
Brawler006 Brawler006 is offline
#1206 (Wrench Warriors)
Brawler006 is an unknown quantity at this point
Re: Programming port burning hot
Ours gets kinda hot, but you can still touch it. I'm guessing that it's normal, but we added some fans to blow on it.
Unread 25-02-2004, 23:57
Aignam's Avatar
Aignam Aignam is offline
This Space For Sale
AKA: Anthony Mangia
#1257 (Parallel Universe)
Team Role: Scout
Aignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant future
Send a message via AIM to Aignam Send a message via Yahoo to Aignam
Your programmer must have been 'on fire'.
Some Thoughts to Ponder
How does a sign turn into a lady friend? Don't optional stop signs ruin the purpose? What are pneumatics? Am I really banned from 229 for life? Can walls get bigger?
Aignam. Pronounced A-Num. Mangia backwards.
NJFIRST.org | Best Thread. Ever.
AIM: Aignam | ICQ: 265237569 | E-mail: AnthonyMangia@aol.com | HTTP: www.aignam.com
Unread 29-02-2004, 02:36
NotQuiteFree's Avatar
NotQuiteFree NotQuiteFree is offline
Do the WAAAAVE!!
#0957 (Watson)
NotQuiteFree will become famous soon enough
Send a message via MSN to NotQuiteFree
Well, we were having the same problem with our RC a while back. Now, I know you've already shipped, but when you are able to get back to looking at it, you may want to check the voltage on the frame. We were getting 5 volts running out of one of our Bosch motors and grounding to the frame. Our program port itself didn't get hot, but we actually melted the casing on the cable. So, just as a precaution, I would be absolutely sure to check the frame for voltage.
Yo.
Unread 01-03-2004, 00:19
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
This is a very good suggestion, for several reasons. In addition to potentially causing your problems, if you do have a short to the frame it is likely to cauce several other issues as well. In addition, having a hot ground to the frame is a no-no under the FIRST rules.
Inspectors will check for this, and if they find your frame is hot you will have to correct it before you can compete. If the frame is hot due to an accidental short, you will want to know and get this corrected ASAP anyway (and maybe replace one or two wires). But if it is hot because you designed the ground in your electrical system this way, then you will have to re-wire the entire system (NOT a fun situation at the start of a competition!).
-dave
Unread 02-03-2004, 09:47
Greg McCoy's Avatar
Greg McCoy Greg McCoy is offline
boiler up!
FRC #3940 (CyberTooth)
Greg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond repute
Send a message via AIM to Greg McCoy
Yeah, I believe we had this problem last year and didn't realize it until we blew like 4 or 5 Victors or something crazy like that. Check for contunity frequently between your frame and your fuse panels (when the robot is off )
Banner Sensor Programming Problem 2Crisis Programming 4 24-02-2004 13:40
PWM and burning out motors patrickrd Technical Discussion 7 19-06-2003 15:30
Fried program slots? Jeff Waegelin Programming 18 19-03-2003 18:08
Change to Initializing Inputs and Outputs Jferrante Programming 4 07-01-2003 11:36
Programming Port GreenDice Programming 12 10-01-2002 09:14
