Go to Post We could not make weight so we got rid of the cRIO. - Mike Copioli [more]
Unread 29-02-2004, 12:28
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
Re: Creating no pressure with double solenoid?
Originally Posted by Jeffrafa
there is a much easier way....
you can simply use a three-position valve, it works just like a dual solenoid (and looks almost identical), but when you aren't sending electricity to either of the solenoids then it springs to center. This engages "all ports blocked" which basically means no air can flow through the valve at all
we are using two of these on ours, the only thing is you can't pulse power unless you have it give power just long enough for the cylinder to extend.
the advantage is that if you loose air pressure in you're entire system, then that device will still stay wherever you had it assuming it was in the center-off position. the only problem with this is that it takes air to actuate the solenoid (since the solenoid is like a mini-cylinder) so until you regain pressure on the incoming line you will not be able to release the cylinder from the position it was in.
Where did you get these valves? It's to late for us to get them this year... but this would be a big help in the future.
Thanks Tom Cooper
Unread 29-02-2004, 20:45
Jeffrafa's Avatar
Jeffrafa Jeffrafa is offline
Robotics Addict
AKA: Jeff Lewis
FRC #1425 (Error Code)
Jeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant future
Most any Pneumatics distributer would have them.
Norgren, SMC, Festo, and Parker all make and carry three position solenoid valves.
Unread 29-02-2004, 22:45
occra 23.
AKA: ryo
None #1481
WHAT!!!!?!???
we were allowed to use 3 position ones!?!?!?!
i never knew that!! oh, well... if only i knew... would have saved about 2lbs...
(our double solenoids are about 1.5lbs each. oh, so if any one has any spare lighter ones, we'd really appreciate it if you can exchange them for our heavy ones even just for the 3 days.
Double Solenoid Wiring blindguyinanorg Pneumatics 7 09-10-2004 23:55
Double Solenoid Wires Lord Nerdlinger Pneumatics 4 17-02-2004 19:54
using single solenoid like a double SteveO Programming 14 02-02-2004 22:51
Anyone willing to trade (something they need) for the SMC double solenoid? Jeremy Kit & Additional Hardware 0 27-01-2004 20:14
Will trade for double solenoid valve archiver 2001 2 24-06-2002 00:33
