Go to Post You are all analyzing the words of a 300 pound fuzzy Pooh Bear with a penchant for squeezing other human beings for fun. Saturday is coming fast. Go see a movie. - Rich Kressly [more]
Unread 27-02-2004, 22:21
Jones571's Avatar
Jones571 Jones571 is offline
AKA: Corey
FRC #0571 (Paragon)
Jones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud of
Send a message via AIM to Jones571
Re: pic: Here's RAGE
they are running 6 of the 6 inch skyway tiers they doubled them up in the middle and the back. they are running a basic trani with just drill motors. great for pushing power and by lowering the middle axles just a little it has greatly improved there turning
*scary i know more about there robot then they do, maybe they need to make us pay rent we are at there facility way to much
Unread 27-02-2004, 23:55
Jon K. Jon K. is offline
n.e.r.d #6
Jon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond repute
Like I said I know nothing really about technical stuff. I am just around the engineers enough while they are building that I get a general jist of it. Were we build is in the same room as our new CNC machine at one of the high school's so I usually get stuck deburring etc. And yes I love dew
Unread 28-02-2004, 11:31
Lisa Rodriguez Lisa Rodriguez is offline
Biology Grad Student.....
AKA: Lisa Rodriguez
FRC #0173 (RAGE)
Lisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant future
Send a message via AIM to Lisa Rodriguez Send a message via MSN to Lisa Rodriguez
Hey, just because Jon doesn't know about the drive train doesn't mean we all don't. Yes it's 6 wheels, using only the drills, no atwoods this year. Again two speeds, blah blah blah. Yes corey, you're at our facility a LOT, but that's only because we love you. We build our robot @ our high school, but don't pay janitors, we just go when other people are there (that's the one of the reasons we like wrestlers they practice all the time) Also, the 2 rubber bands are of the rollers so they don't get streched and there are no motors on the basket yet. The basket isn't the same as 02, but looks similar in the picture, once i get better picture of the robot i'll be sure to post them, but we were REALLY tight on time, so this was the only shot we have when Jon snuck into the machine shop during school. The arm that sticking up DOES come down to fit for the begining of the matches, and it extends to about 11 feet.
That's all i can think of right now.
And no Jon, you only deburr cuz we pin you down and make you, you whined and complained so much we almost put duct tape on your mouth :-p
This thing still works?
it's never over unless you let it be over
Unread 29-02-2004, 00:18
bush173 bush173 is offline
AKA: Matthaw Bush
#0173 (RAGE)
Team Role: Scout
bush173 is an unknown quantity at this point
yea thats true, he even had to go through a little training thing just to learn how to deburr. he just likes playing with the sprockets
"It says 'Do not install backwards, charge, put in fire or mix with other types- may explode or leak causing injury.' I think they're talking about people, not batteries."
Unread 29-02-2004, 02:14
Katy's Avatar
Katy Katy is offline
Quis custodiet ipsos custodes?
Katy has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond repute
Send a message via AIM to Katy Send a message via MSN to Katy
how much does the arm weigh/how long is it?
Unread 29-02-2004, 10:35
n.e.r.d #6
The arm weighs quite a bit. I am not sure of exact figures but i am guessing around 20 lbs complete. That is not including our mast. The arm in that picture is not fully extended, but when fully extended it can reach the bar no problem. I believe it can go up to 10-11 feet total.
Unread 29-02-2004, 12:12
AKA: Lisa Rodriguez
FRC #0173 (RAGE)
I think the arm weighs a little more than that, not sure, but it fully extends to 11 feet
Unread 29-02-2004, 12:36
AKA: Matthaw Bush
#0173 (RAGE)
Team Role: Scout
the arm weighed about 20 lbs when we still had the 2X grabbers, but we needed to save weight so off thay went along with around 6 lbs, so the arm is almost 15 lbs now
Unread 29-02-2004, 12:41
David Bridge's Avatar
David Bridge David Bridge is offline
Totally Sweet... Man
FRC #0177 (Bobcat Robotics)
David Bridge will become famous soon enoughDavid Bridge will become famous soon enough
Send a message via AIM to David Bridge
so will rage not be trying to manipulate the 2x balls at all, or are you planning on astonishing us all as usual by using those innovative skills to come up with a light weight way to do it?
Unread 29-02-2004, 20:18
AKA: Lisa Rodriguez
FRC #0173 (RAGE)
I'm afraid we cannot say
Unread 29-02-2004, 20:28
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
shhhhhhhhhhhhhhhhhhhhhhhhhhhhhh! don't give them any ideas!
an another note, I just realized that any of the robots that rage has built since 2000 could (with only a few minor modifications) pose some serious competition to this year's game. I think that at one of the post-season comps this year there should be a match that is Rage + Rage vs. Rage + Rage, Four years representing. i predict a close call with 2004 and 2001 rarely beating 2002 and 2003.
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 29-02-2004, 20:37
Now THERE is an idea... What about a post season comp where it was ALL robots from previous years. I for one would love to see how a lot of past robots would do in this years game. I mean the big balls are the exact same as 2001, and the small balls have been around for a while. We could even take it a little further and invite back alumni drivers and see if they still have what it takes!
Unread 29-02-2004, 21:03
Elgin Clock's Avatar
FRC #0237 (Black Magic)
I'm assuming that this would mean that the previous year's robots would have to be intact...
Unread 29-02-2004, 22:00
AKA: Lisa Rodriguez
FRC #0173 (RAGE)
If you wanna come over some night, Jake, and make them all work, that's fine BUT
'02 is intact for OBVIOUS reasons
'03 is still running, but kinda broken, actually, i'm not sure, i believe someone fried a transmission, but we can fix that
'01 is at the high school (how much is it when we set of the alarm, $300??)
and I'm pretty sure the '00 bot has been salvaged for parts
We COULD fix them, but it would take time and $$$, but maybe during the offseason........
it's not like we don't have a field
ps-i'm also not sure we have the controls....or programming, but like i said, offseason project....
Unread 01-03-2004, 15:49
n.e.r.d #6
a: I love my sprockets
b: so what if I didn't know how to deburr right
c: stop picking on me.
pic: RAGE Bot 2003 in action CD47-Bot Extra Discussion 8 30-03-2003 00:29
pic: RAGE Bot at the UTC Regional CD47-Bot Extra Discussion 4 17-03-2003 22:23
No Rumor....River Rage Will Happen! archiver 2000 0 23-06-2002 23:22
River Rage Finals Results Justin Off-Season Events 0 12-09-2001 22:49
