Go to Post To offer an opinion is fine, to demand that others adhere to your opinion is laughable. - JVN [more]
Unread 29-02-2004, 16:58
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: Team 57 Revealed
Unread 29-02-2004, 17:00
Ryan Albright's Avatar
Ryan Albright Ryan Albright is offline
Just Browsing
AKA: ryan albright
Ryan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond repute
Send a message via ICQ to Ryan Albright Send a message via AIM to Ryan Albright Send a message via MSN to Ryan Albright Send a message via Yahoo to Ryan Albright
Re: pic: Team 57 Revealed
i see that you guys sit high, you planning on going up the ramp, and if so why did you choose casters and how are they on the ramp. What exactley can your arm do?
Alumni of 710 2001-2004
Mentor 1083 2005
2005 UCF regional lead safety advisor
2005 Championship Safety advisor
Unread 29-02-2004, 17:12
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
That would be that we WERE trying to go up the ramp. we had issues with not turning with our 4-WD and the motors stalling because of it. then they'd come back on at full speed and the shock load was tearing a gear in our transmissions to shreds. The arm telescopes so that we can hook into the bar from the floor.
Unread 29-02-2004, 17:40
OneAngryDaisy OneAngryDaisy is offline
not on CD enough...
OneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of light
That arm looks quite familiar.. Looks like you're using the Fisher Price to move the arm up, are you using all of the gears that came in the gearbox? Also, how are you winching and pulling the robot up?
Looks very sleek, I like the black theme
Unread 29-02-2004, 20:33
There's a winch directly beneath the base of the arm, with a spectra cable running up and through the inside of the arm. The winch is actually a small lightweight boat winch, currently driven by the WINDOW motor. We might be swapping in a drill mtor in low gear and engaging the racheting mechanism on the winch, since the WINDOW motor is a little slow at the moment. Luckily it's mostly a drop in change since the input on the winch is now a 5/8" keyed shaft.
Last edited by Kevin Sevcik : 01-03-2004 at 01:17. Reason: Can't remember a seat motor isn't a window motor
Am I the only person with this job? A. Leese General Forum 55 22-06-2006 20:10
Real names, please Andy Baker General Forum 131 21-07-2004 22:07
Loss of Gracious Professionalism Among First Teams Melissa Nute General Forum 82 31-03-2003 19:34
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
