Go to Post I'm tired of quoting the manual for today so all I will say is "Try again". - Vikesrock [more]
Unread 21-02-2004, 09:44
Combat Chuck Combat Chuck is offline
Team Role: Scout
Combat Chuck is on a distinguished road
Creating no pressure with double solenoid?
Hey. I was wondering if it's possible to have no air coming out of the double solenoid during competition. Right now we have it where the solenoid will act both ways, but until we pulse the solenoids, the pistons are retracting, which causes stress on our frame. Is there a way to have it where both of the solenoids can be off at the same time? Thanks.
Unread 21-02-2004, 10:21
occra 23.
AKA: ryo
None #1481
Re: Creating no pressure with double solenoid?
one way is to use another solenoid inline before the solenoid you are using now.
ex) use a single before your double and plug the B and have a tube go from A to the double solenoid. have the tank connect to P.
so when there is no signal to the single, air will not go to the double resulting in no movement in your cylinders.
or,
use the configuration of being able to stop your cylinders at any point..
by just connecting a 3 way splitter to both exhausts of your double, and connecting another tube from that splitter to the P of another single solenoid. plug the B of the single and leave A open.
that way, you can stop the exhaust of your double by controlling the single. stopping exhaust of the double=no movement in your cylinders.
if you didn't understand or have any questions, i'll be happy to answer!
just pm or Email me.
Unread 29-02-2004, 05:30
Jeffrafa's Avatar
Jeffrafa Jeffrafa is offline
Robotics Addict
AKA: Jeff Lewis
FRC #1425 (Error Code)
Jeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant future
there is a much easier way....
you can simply use a three-position valve, it works just like a dual solenoid (and looks almost identical), but when you aren't sending electricity to either of the solenoids then it springs to center. This engages "all ports blocked" which basically means no air can flow through the valve at all
we are using two of these on ours, the only thing is you can't pulse power unless you have it give power just long enough for the cylinder to extend.
the advantage is that if you loose air pressure in you're entire system, then that device will still stay wherever you had it assuming it was in the center-off position. the only problem with this is that it takes air to actuate the solenoid (since the solenoid is like a mini-cylinder) so until you regain pressure on the incoming line you will not be able to release the cylinder from the position it was in.
Unread 29-02-2004, 05:54
Jeffrafa's Avatar
Robotics Addict
AKA: Jeff Lewis
Since it sounds like you are trying to not send pressure you could also use a three position valve that is "all ports open" in center position.
This means that it works just like the dual except if you don't send a signal to one of the solenoids then it will open up both cylinder ports to exhaust, therefore releasing all pressure in the cylinder and allowing it to freely move.
Unread 29-02-2004, 12:16
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Do you mean that you want to stop the cyclinder at a certain position and not have it fully retract and extend?
If that is it check here: http://www.chiefdelphi.com/forums/sh...ighlight=multi
Unread 29-02-2004, 12:28
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
Where did you get these valves? It's to late for us to get them this year... but this would be a big help in the future.
Thanks Tom Cooper
Unread 29-02-2004, 20:45
Jeffrafa's Avatar
Robotics Addict
AKA: Jeff Lewis
Most any Pneumatics distributer would have them.
Norgren, SMC, Festo, and Parker all make and carry three position solenoid valves.
Unread 29-02-2004, 22:45
occra 23.
AKA: ryo
None #1481
WHAT!!!!?!???
we were allowed to use 3 position ones!?!?!?!
i never knew that!! oh, well... if only i knew... would have saved about 2lbs...
(our double solenoids are about 1.5lbs each. oh, so if any one has any spare lighter ones, we'd really appreciate it if you can exchange them for our heavy ones even just for the 3 days.
Double Solenoid Wiring blindguyinanorg Pneumatics 7 09-10-2004 23:55
Double Solenoid Wires Lord Nerdlinger Pneumatics 4 17-02-2004 19:54
using single solenoid like a double SteveO Programming 14 02-02-2004 22:51
Anyone willing to trade (something they need) for the SMC double solenoid? Jeremy Kit & Additional Hardware 0 27-01-2004 20:14
Will trade for double solenoid valve archiver 2001 2 24-06-2002 00:33
