Go to Post Welcome to FIRST! It's in your blood now... - AmyPrib [more]
Unread 29-02-2004, 21:27
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Re: How hard is it to CNC this?
Originally Posted by ahecht
Other than the keyway, it should be fairly easy to CNC. The keyway would be phisically impossible to mill (unless you have a 90 degree end mill, which may not even exist), and would need to be broached.
Also the spaces between the 6 stading posts can not be milled due to you wanting them to be square. If you dont mind that space being a circular gap, it could be done. Though if it needs to be a square gap, it would have to be cut out with a saw most likely.
Edit: ok you can mill the spaces and get a circular gap then grind/sand/file it to square but i doubt it would look or act as if you did it with a saw if you want it to be square.
-Michael Dessingue
Why was stacking so hard? Tton General Forum 39 16-03-2003 19:17
Potential Hard Drive on RC? Goya Programming 10 09-01-2003 13:55
Super Hard TV/Movie Test Aaron Lussier Chit-Chat 8 13-12-2002 06:40
Are you hard core or not? Joe Johnson Championship Event 7 25-04-2002 23:05
How hard is it to pull a goal? Ken Leung General Forum 19 17-01-2002 20:09
