Go to Post Don't forget Morgan Freeman will be at champs. Maybe he and Will are gonna freestyle it! - Nuttyman54 [more]
Unread 29-02-2004, 23:18
bigqueue bigqueue is offline
#0811 (A.R.C.)
bigqueue will become famous soon enough
Send a message via AIM to bigqueue Send a message via Yahoo to bigqueue
Re: Optical Sensors Used as Encoders?
Originally Posted by uvabrad825
I'm sure on past robots teams have tried to use their optical sensors as an encoder by placing bits of reflective tape on a wheel/sprocket and counting the number of times a sensor mounted to read the pieces of tape was 'activated' (I'm not a programmer so I don't exactly know the correct terms).
Our team is considering pursuing this idea once we uncrate our robot at regionals, having the programs pre-written. We are planning on putting 8 evenly spaced pieces of reflective tape on the rims of our back wheels, and mounting two optical sensors to appropriately interact with the pieces.
I was wondering if any teams in the past have had success (or lack of) with this procedure, and if so, what the optimal setup(s) are (tape spacing, distance from sensor to wheel, etc..). Our programmers are very good at what they do, so I don't think that will be a problem. Any advice would be greatly appreciated!
We did this exact thing last year and ot worked out pretty well. We split the coupling on our motor with tape. (half tape) and then made a quadrature encoder by using two optical Banners at 90 degrees from each other. THis way we knew of the wheel was spinning forward or reverse.
This worked out well, and given the ratio of this motor coupling to the output wheels, we had about a 3" resolution on out drive position.
It all worked out pretty well, but the thing that killed us was momentum when we stopped driving the motor. We had much overshoot at first, and much oscillation when we tried to impliment feedback.
Good luck,
-Quentin
Live free or die....
Unread 29-02-2004, 23:23
Umm Errr...
Just me 2 cents, but if you are going to go through the trouble to do all this, then why not just use encoders or gear tooth counters?
If you use reflective tape and banner sensors, it will work, but i don;t see how you can possibly get much resolution.
1139 Alumni
Unread 29-02-2004, 23:38
uvabrad825's Avatar
uvabrad825 uvabrad825 is offline
#0825 ('swi-va-gus 'mak-sa-mus)
uvabrad825 has a little shameless behaviour in the past
Mostly because our team has a serious lack of $$$ and time, and since we have the banner sensors and can easily acquire some tape or white paint to put on our wheels, it's worth the try. And we're hoping that with enough 'markers' we can get it accurate enough for our purposes....
Thank you everyone for all of your help....
Unread 01-03-2004, 00:44
Greg's Avatar
Greg Greg is offline
FRC #1075 (Sinclair Sprockets)
Greg is on a distinguished road
Send a message via ICQ to Greg Send a message via MSN to Greg
Personally, I think unless the bot is very slow, the extra resolution wont matter. You still cant stop the bot theres just too much inertia. And we are not using the sensor on the actual wheel. We have it on a gear that is in a ratio of about 18:1 to the wheel. So that increases the resolution. And about the tape... The rules say "no adhesive-backed tape on the robot. The only exception is electrical tape, and it can only be used as as insulator". So a "decorative" explanation might not go over with the inspectors too well. White paint works very well, and is completely legal.
Unread 01-03-2004, 07:59
We used Banner sensors last year for wheel encoders and have included them this year as well. We use a custom wheel so when the wheel was being assembled we just slipped a piece of dark papaer between the spokes of the wheel. By using two encoders (outlined above) you can tell direction and distance traveled. Last year we were able to get accurate down to at least an inch which made auto mode pretty easy. You need to couple the wheel sensors with a direction device to really know where you are.
Unread 01-03-2004, 16:41
KevinB's Avatar
KevinB KevinB is offline
AKA: Alum
Last year we used banner sensors and tape marks, but this year we went ahead and spent a whopping $80 for shaft encoders (300 clicks per revolution ... as opposed to the 8 at best we had before).
Unread 01-03-2004, 17:36
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
I read all the First Questions and answers last night and they said that reflective tape for pulse generation is legal. As long as they don't change their minds like they did with the yaw rate sensors life will be good.
Unread 01-03-2004, 17:34
AKA: Tom Cooper
Not counting slop in the chains, I'm predicting .3 in resoulition We will be testing and codeing on a drive mock up built with some unused but gorgeous double bearing blocks and last years Cim motors. Hopefully we can make it all work in our "Drive system lab"
jacob_dilles's Avatar
jacob_dilles jacob_dilles is offline
AKA: theshadow
FRC #0620 (WarBots)
jacob_dilles will become famous soon enough
Send a message via AIM to jacob_dilles
lol we dont need 1/4 degree resoluton. we need to know GENRALY how many times the wheels have turned...
"You're not a real programmer until all your sentences end with semicolons;"
Unread 01-03-2004, 21:44
ErichKeane ErichKeane is offline
FRC #3210
ErichKeane is just really niceErichKeane is just really niceErichKeane is just really niceErichKeane is just really niceErichKeane is just really nice
Send a message via AIM to ErichKeane
Well, it shouldnt be hard to figure out w/ the code example i posted. Let me know if it comes in handy
Unread 01-03-2004, 23:47
ECarlson's Avatar
ECarlson ECarlson is offline
AKA: Eric Carlson
#0116 (Epsilon Delta)
ECarlson has a spectacular aura aboutECarlson has a spectacular aura about
We tested the banner sensors to measure RPM's, and from what I saw it worked quite well, but our team decided to go with shaft encoders.
We also were going to use a potentiometer to measure the position of our arm, but also went with shaft encoders for that since the potentiometers from RadioShack were only responsive over about 180 degrees of their range, and we needed the full 270 degrees. We could have geared down the potentiometer, or gone with higher quality potentiometer, but we already had the shaft encoders.
- Eric
www.InvisibleRobot.com Updated: August 24, 2008
Over 28,000 FRC & FTC Photos , Team 116 OI adapter board info
Q&A Discuss: Optical sensors with EduBot CD47-Bot Extra Discussion 2 01-03-2003 18:37
Q&A Discuss: optical sensors CD47-Bot Extra Discussion 0 15-02-2003 22:58
optical sensors great_one411 General Forum 1 15-02-2003 19:54
optical sensors acting strangely rosebud Electrical 10 03-02-2003 00:29
optical sensors majormusic2005 General Forum 1 28-01-2003 20:37
