#16
Re: How hard is it to CNC this?
you can actually do it on a vertical mill if you have the 1/8th inch long endmill. But you must lathe it down first and then put it in an indexing head. Then if you have the time you can rotate the piece while lowering the endmill after each rotation. Then make all the other cuts you must.
#17
Another option would be to make it in seven pieces instead of one. I would make the "orange wedges" seperate pieces that attach to the hub with machine screws - 10-32, perhaps.
| Why was stacking so hard? | Tton | General Forum | 39 | 16-03-2003 19:17 |
| Potential Hard Drive on RC? | Goya | Programming | 10 | 09-01-2003 13:55 |
| Super Hard TV/Movie Test | Aaron Lussier | Chit-Chat | 8 | 13-12-2002 06:40 |
| Are you hard core or not? | Joe Johnson | Championship Event | 7 | 25-04-2002 23:05 |
| How hard is it to pull a goal? | Ken Leung | General Forum | 19 | 17-01-2002 20:09 |
