Go to Post I'm really impressed with how much effort we'll go to, to avoid buying a $25 servo tester. - MrForbes [more]
  #31   Spotlight this post!
Unread 01-03-2004, 10:14
Re: Dashboard
Originally Posted by Ian W.
It may be able to read TCP ports though, in which case you can (I think) easily pipe the data through an obscure TCP port that no one else would be using. I'll look into that over the next few days.
Have you looked into using sockets? That's what I'd use for inter-process communication.
  #32   Spotlight this post!
Unread 01-03-2004, 13:39
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Dashboard
Originally Posted by jacob_dilles
does anyone know anything about accesing ram in flash? i know you can do it in C++... so like instead of writing to a file which has got to be bad; i dont know why its just badl; you just share a couple of bytes in ram. the flash could call the c++.
trying to thing of a way to get around the file I/O
Why??? Creating a file then deleting it doesn't take long; Even in VB, Open a file, writting to it, and closing it doesn't take long.
  #33   Spotlight this post!
Unread 01-03-2004, 15:14
jacob_dilles's Avatar
jacob_dilles jacob_dilles is offline
AKA: theshadow
FRC #0620 (WarBots)
jacob_dilles will become famous soon enough
Send a message via AIM to jacob_dilles
Re: Dashboard
its the princaple of the thing. at least use scrachpad ram or something. it works, but that doesnt meen its the right way to do it.
"You're not a real programmer until all your sentences end with semicolons;"
  #34   Spotlight this post!
Unread 01-03-2004, 15:17
Venkatesh Venkatesh is offline
FRC #0030
Venkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to behold
Re: Dashboard
I wrote a small dashboard interface program in QBASIC, which read the data from the serial port, mangled (processed) it, and stored the output in text files.
Then I wrote a program in Java, which read those text files and displayed the data on screen in a fancily-formatted window. I used the AWT for graphics, 'cause I don't know how to program Swing yet.
Btw, to improve the speed of text-files for communication, I created a RAM disk. The output files are outputted from BASIC into the RAM disk. I find the speed to be no problem.
-- vs, me@acm.jhu.edu
Mentor, Team 1719, 2007
Team 30, 2002-2005
  #35   Spotlight this post!
Unread 01-03-2004, 15:21
AKA: theshadow
FRC #0620 (WarBots)
Re: Dashboard
lol exactly. thats what im talking about. except theres a way to do it WITHOUT a ramdisk... its called direct access...
but anyway have an old OI and RC (yes i know its diffrent but the princaple is the same) and i have a program in c++ that gets the data realy well. there is an obscure class that lets me write to ram, but getting it from anythign else was a problem.
i may have it use a ramdisk if i cant figure out anything else before richmond.
btw if you wana post your QBASIC it may help some people that dont know the language and need somewhere to start.
  #36   Spotlight this post!
Unread 01-03-2004, 16:25
FRC #0030
Re: Dashboard
I would post both my BASIC code and the Java code if I still had it. However, it is currently in a location where I won't have access to it for approximately a month. So its not of much use to anybody...
Team 30, 2002-2005
  #37   Spotlight this post!
Unread 01-03-2004, 20:07
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
Re: Dashboard
Perhaps that's what I was told we could use last year, I'm not sure.
I've been looking into how easy it'd be to change the dashboard from file I/O to sockets (which is the right term for what I want, I think). I think it should be easy, but I'm still looking for a nice class to do all the hard socket work for me .
AIM --> Woloi
Email --> ian@woloschin.com
  #38   Spotlight this post!
Unread 01-03-2004, 20:10
College? What?
Re: Dashboard
Did you create a ramdisk under Windows or Linux?
I know how to do it under Linux (well, not exactly, but I know where to look to find out), but I have no idea how to do it under Windows. And for the dashboard program I'm using Windows to appease the rest of my team .
AIM --> Woloi
  #39   Spotlight this post!
Unread 01-03-2004, 20:49
FRC #0030
Re: Dashboard
My Ramdisk is running under Windows.
The easiest way (for Windows 95/98) is to place a line for RAMDRIVE.SYS in your config.sys files. PM me if you need help doing what I am talking about.
Under Windows NT, 2000, and XP, you must download a driver from Microsoft. The driver is a sample driver, demo-ing NT-based drivers. It is neither stable nor debugged, but it works for what I am doing.
Team 30, 2002-2005
  #40   Spotlight this post!
Unread 01-03-2004, 21:05
Kevin Karan's Avatar
Kevin Karan Kevin Karan is offline
Linux Guy
AKA: maxdamage
None #0174 (Arctic Warriors)
Kevin Karan will become famous soon enoughKevin Karan will become famous soon enough
Send a message via AIM to Kevin Karan
Re: Dashboard
Incase anyone was wondering, Im currently porting the reciever code into a visual basic control (ocx) so anyone can just slap it into their own dashboard nice and easy, with this you could make a dashboard interface and a skilled coder could have it up and running in an hour or so. Im still testing and optomizing it and I would like to have a first release by next week. I will release pre-compiled binarys, the source for them, as well as an example app that shows how it would be used. It will differ from other dashbord control moduals in that I WILL be releasing the source and I WILL be parsing all of the data frames allowing for every single bit of usable data to be utilized.
It isnt ALWAYS the programmers falt!
2004: Buckeye team website award
2002: Rutgers semi-finalists
2001: National semi-finalists
2001: Rutgers semi-finalists
1998: Manchester Rookie All-Star Award
  #41   Spotlight this post!
Unread 01-03-2004, 21:27
AKA: theshadow
FRC #0620 (WarBots)
Re: Dashboard
*big hug*
  #42   Spotlight this post!
Unread 02-03-2004, 07:30
AKA: Jamie Bliss
Re: Dashboard
I LIKE YOU!!!!
  #43   Spotlight this post!
Unread 04-03-2004, 15:16
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: Dashboard
Thanks a lot. That will be a lot of fun to play around with, not to mention a great time saver.
  #44   Spotlight this post!
Unread 04-03-2004, 15:31
AKA: Jamie Bliss
Question Re: Dashboard
Is there a way to tell (in code) what year's dashboard stuff your getting? Especially post-season, I'm sure we're going to be playing with both (may be in the same thing!), so 1 program would be nice.
  #45   Spotlight this post!
Unread 05-03-2004, 08:15
Linux Guy
AKA: maxdamage
Re: Dashboard
This year isnt compatable with previous years, the packet format is different
New dashboard packet spec Ameya Programming 2 08-01-2004 19:59
Dashreader.dll: A Visual Basic .NET user control to read the dashboard port Ameya Programming 4 12-01-2003 23:40
Dashboard Decoder Release Version 1.0 Now Available! archiver 2000 1 23-06-2002 22:50
New Innovation FIRST control system and the dashboard archiver 2000 0 23-06-2002 22:15
Dashboard Viewer Khalicl13 Technical Discussion 8 15-06-2001 23:36
