Go to Post Diversity means diversity in ideas too. Some of the robots from the singapore competition might have employed strategies or ideas that we may not even have come up with in North America. - J Flex 188 [more]
Unread 03-02-2002, 13:02
Tyler Olds Tyler Olds is offline
FUN Show Host
no team (First Updates Now)
Tyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond repute
Smile Net Rendering
Hey everybody how ya'll doin?
Just a question abouit net rendering on R3.1
Can you net render on more than one comp at a time? I know you can on other programs like Bryce and stuff. But whenever I try to click on more than one comp for net rendering, It doesnt let me. Am i doing something wrong? Please let me know.
Thanks
First Updates Now Show Host.
Watch and Listen to FUN on Youtube, iTunes, and www.firstupdatesnow.com
FRC Emcee 2009-2016: Team 2826 Wave Robotics Lead Mentor 2001-2004 Team 93 NEW Apple Corps Alumni
CD Moderator
Unread 03-02-2002, 13:12
Daishichimaru Daishichimaru is offline
Daishichimaru is an unknown quantity at this point
Send a message via AIM to Daishichimaru
I've never done it personally, but the manuals go over it quite well.
Man is the ape that laughs.
Unread 04-02-2002, 16:43
zorro zorro is offline
#0292 (PantherTech)
zorro is an unknown quantity at this point
Send a message via AIM to zorro
The net rendering machines all have to be running NT or 2000. You start the net render server on each machine you wish to render with. You also have to have one of these machines run the net render manager as well. After you do this, goto max, choose net render and just highlight the servers you wish to render with.
Greg Szorc
gregszorc@cwru.edu
Unread 04-02-2002, 17:34
FUN Show Host
Talking been there done that
Yeah i already did that,
My problem is that it only lets me click on one comp!!!
Idk why it does this I think I might just contact autodesk about it unless I get a responce in a day or 2.
Thanks
CD Moderator
Unread 03-03-2002, 22:06
Mikey Mikey is offline
#0068 (Truck Town Thunder)
Mikey is an unknown quantity at this point
Send a message via AIM to Mikey Send a message via Yahoo to Mikey
Talking Network
Try making sure that the actual network is set up well, make sure that all yoru subnets are the same etc...on team 68 we had the same problem, we edited the subnets to make them all the same and we were able to do net rendering just fine.
-=Mikey=-
Unread 03-03-2002, 22:09
#0292 (PantherTech)
In order to render on more than one system at once you have to set the output mode to image. I recommend tiff format so you have no quality loss. Once you do this you can output to all available servers. Make sure you have plenty of disk space though, the tiff's come to about 1 MB per frame. After the rendering is done you will have sequentially numbered frames which you can combine into a movie.
Greg Szorc
gregszorc@cwru.edu
Unread 04-03-2002, 12:18
FUN Show Host
converters?
does anybody know where/ how to make .tiff or some kind of images into .avi? or some type of converter that i can download?
Thanks
CD Moderator
Unread 04-03-2002, 14:30
We use Adobe Premiere to turn image frames into an AVI file.
-=Mikey=-
Unread 04-03-2002, 17:45
I've looked and can't find anything good that isn't warez but is free.. Sucks to have no money for the animators. :| I *think* you might be able to load sequentials into RAM player and have it feed out a stream, but the RAMplayer avi output sucks. Good if you have a few spare gigs of ram sitting around and just want a preview, I guess...
Unread 05-03-2002, 19:42
FUN Show Host
adobe
Hey i got a question,
How do you convert the images on adobe premier to .avi? could you please give me a process of doing this?
CD Moderator
Unread 05-03-2002, 21:16
Talking
I'll try and write a quick howto, however my knowledge is somewhat limited. If it's not detailed enough, please feel free to IM me: xschwinnx or e-mail me webmaster@wlcthecall.com I'll glady give all the advice I have =)
Well the first step is to take all of the still frames and connect them so to speak. You do this by going to your window where you import video clips (sorry that I don't know the proper name) and right clicking. Then choose import. Click once on the first frame and then at the bottom of the window you should be able to check a box that says 'numbered stills'. Once you do this it will link all of the files together as an actual animation clip.
With this animation clip you drag and drop it into your timeline for the animation. Once you have all the clips where you want them, transistions, sound, etc... Then it's time to export to video.
Go to file and choose export, from there you should be able to select the file type in a drop down box. Choose avi, and watch it go!
-=Mikey=-
Unread 05-03-2002, 22:05
Sunny Thaper Sunny Thaper is offline
None #0064 (The Gila Monsters)
Team Role: Animator
Sunny Thaper is an unknown quantity at this point
Send a message via AIM to Sunny Thaper
Cool
Max has a built-in feature that is called Video Post in which you can stream camera shots together, add pictures, I belive you can add sound but I may be mistaken but anyway you can "Add Image Input" and click on "Files" which will take you to an open dialog and from there you find the first frame of your animation, click the "Sequence" checkbox and click open. That should import everything and now you can save the video post file as an avi.
Unread 13-03-2002, 17:29
VanWEric VanWEric is offline
#0250 (Dynamos)
VanWEric is an unknown quantity at this point
reverse
Any idea on how to reverse time on the film? I tried to bomb some text and then view it in reverse, but the only way i found was to render it by frame list ie 20,19,18....3,2,1. THis is really annoying if you have more than 20 frames. the range feature refuses to have a start higher than its end. oh well. OR... can i make a bomb go in reverse? perhaps setting the strength to negative or some other odd gimick
Unread 15-03-2002, 08:32
Zeinin Zeinin is offline
#0449 (Blair Robot Project)
Zeinin is an unknown quantity at this point
Send a message via AIM to Zeinin Send a message via Yahoo to Zeinin
do most of your effects in premire/final cut.
actually.
like, render out that clip as frames and then import it into premire and use that.. but all i gotta say is WHY DID YOU USE TEH BOMB? bombs are sooooo nasty looking..
1.4 gzh athlon TBIRD
512mbs ddr
GeForce 3
SBLIVE 5.1
Unread 15-03-2002, 15:55
#0250 (Dynamos)
well pah!
Actually, the particle field that throws chunks off of a surface does look kinda neat. Any idea where i can find premire/final cut?
Parallel processing for 3dmax mnkysp6353 General Forum 9 06-05-2004 10:26
Rendering help marlon_jbt Website Design/Showcase 10 15-10-2003 21:07
Great Ideas For Next Year's Game MikeT Chit-Chat 0 15-05-2003 23:05
Problems rendering Tyler Olds 3D Animation and Competition 8 24-01-2002 22:34
A (most insane) Network Rendering Crashcourse Robby O 3D Animation and Competition 2 25-09-2001 22:35
