Go to Post My wife got mad at me when I told her I wanted to name our daughter Lotus. "What you mean the software?" she squawked. "No I mean the flower." I said. geeks, I swear.... - Koko Ed [more]
Unread 02-03-2004, 10:39
Re: autonomous IR Navigation
The default navigate code:
- Waits for joystick button to be pushed
- Drives straight away from the back wall
- Locks the IR sensors centered facing forwards
- Turns the robot until the IR sensor locks onto the beacon
- Starts tracking with the IR sensor servos
- Drives the robot towards the beacon
- Stops robot when the IR sensors servos are at a particular angle.
These directives all occur in the navigate.c file. You can add your own code at the end where it says:
case AT_TARGET:
To run properly under autonomous you will have to at least modify the software in user_routines_fast.c (move the call to navigate(); up to User_Autonomous_Mode). The angle the sensor servos are at will depend on your robot and IR sensor mounting. Look in navigate.h at
#define LEFT_GOAL 135
#define RIGHT_GOAL 120
127 should be straight ahead, 120 is off to the side a little bit, 135 is of to the same side somewhat more. A reflection of how far apart the IR sensor servos are.
There are other parameters in navigate.h that you'll need to tweak to match your robot.
A better autonomous method.. randomperson Programming 4 24-02-2004 18:02
Electrical componenets for autonomous navigation maclaren Electrical 10 18-12-2003 02:28
crazy idea for autonomous Mike Ciance Programming 16 24-04-2003 21:50
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Autonomous Kill Switch UCGL_Guy Programming 8 15-01-2003 17:39
