| Thread Tools |
Rating:
Display Modes |
Cool new 2004 Score Calculator Tool
There is a new score calc tool available:
http://www.gmaces.org click on "tools" button. The tool is written in C# so you have to have the c# .net framework on the PC of use. (Free from MS and also part of XP updates). This calc tool range limits so you can't add impossible numbers of balls to goals etc. It also shows winning allience scores. Could be used as a quick score calculator in real time competition. Its fast, easy to use. Jeff Debes |
Re: Cool new 2004 Score Calculator Tool
Good job, but why must you people be evil and make everything ONLY on Windows? I mean, how many Mac users are up on these forums? Quite a bit. So if you could, can you create a nice Mac version?
It only allows you to have 40 balls. When there are 18 +18 + 12 = 48 And then add the 4 ten point balls. You can score 52 small balls in total. With your program allowing you to score a total of 60 in all the goals you need to allow people to score 12 more total balls.
Other than that very good. |
or clarification re: 3 balls allowed in shooter areas? Thanks for pointing the problem out! I'll get an update posted to gmaces.org. Jeff Debes |
We could send you the source code, perhaps it would be not too difficult to make a JAVA version? I don't have the time to do the task right now. Anyway, thanks for your comments. Next time, it will be in JAVA or something. Jeff |
good job! and nice work on the robot.... another good looking rochester robot! look at us multiply...
#7
We appreiciate your teams help. Mobil Goal! Many thanks are in due. Jeff |
#8
jd |
| Using an Operator Interface with the 2004 EDU RC wirelessly | Dave Flowerday | Robotics Education and Curriculum | 34 | 19-04-2004 19:06 |
| 2004 Championship Eligibility Criteria!!! | dez250 | General Forum | 214 | 28-12-2003 20:11 |
| Scoring system for 2004? | DougHogg | General Forum | 11 | 16-04-2003 20:57 |
| Will There Ever Be Negative Scores? | Joe Matt | General Forum | 30 | 18-01-2003 17:15 |
| Will your team behave badly this year? | Kris Verdeyen | General Forum | 19 | 07-02-2002 08:42 |
