Go to Post Didn't you know? Kids today are born with GPS tracking systems installed so Mom's can look them up on Google Earth wherever they are and also know what they're doing for a living, eating the right foods and if they're dating the appropriate people. - Koko Ed [more]
Unread 02-03-2004, 16:53
jacob_dilles's Avatar
jacob_dilles jacob_dilles is offline
AKA: theshadow
FRC #0620 (WarBots)
jacob_dilles will become famous soon enough
Send a message via AIM to jacob_dilles
Re: Digital In Question
Originally Posted by Rickertsen2
Internaly, all of the gnd pins are connected to each other inside the RC.
yep, all the grounds are solderd together inside the box. TECHNICLY you should run a ground wire from each that u use so that your not sinking more curent thurgh the ground then your drawing thrugh the postitives
lol BUT yes one wire will work fine and i doubt its even in the rules... becasue it doesnt realy matter
"You're not a real programmer until all your sentences end with semicolons;"
Unread 02-03-2004, 16:54
ok i was just trying to figure out which pin the RC looks at when trying to see highs and lows.
Unread 02-03-2004, 17:09
AKA: theshadow
FRC #0620 (WarBots)
when you set a pin to be an "input" in the initilzation code, it automaticly sets an internal pull up resistor. when the switch/rotor/encoder/aliean space ship is "off" as in OPEN the I/O reads a "1" on say "rc_dig_io01" or whatever the variable is. you then proceed to wire the switch to the pin and to ground. that way, when it is in the "on" i.e. "CLOSED" postion, the circut is shorted thrugh ground ( but its thrugh a 100 million billion ohm resistor so its not a problem ) and when you read it it calls it a "0"
so when your rotory switch, pic a ground pin, and solder that to the common. then for each "leg", solder it to inputs 1, 2, 3 etc ( actualy, id start at 7 if you dont have any, its an inturpt thing for future expandibity) so 7, 8, 9 etc. then to code it, you can either have a million
if a=0 and b=1 and c=1 and d=1 {do this}
if a=1 and b=0 and c=0 and d=1 {do this}
if a=0 and b=1 and c=0 and d=1 {do this}
or you can have a switch statement. or NESTED switch statements.
or even better, you could have a lookup table! lol have fun with the code tho...
MIM's question of the day on programming. Gene F Programming 3 24-02-2004 16:32
A question about control system options computhief263 Control System 7 04-02-2004 14:46
digital inputs not valid just after initialization? WizardOfAz Programming 2 26-01-2004 13:21
MnM EASY Question of the Day Winners! Mike Bonham General Forum 22 03-05-2002 21:21
Have a question about the Basic Stamp Chip Boards wes16zeus Programming 3 06-12-2001 08:25
