Go to Post Having a spare arm that you can put on in 5 minutes or less intimidates the hardware into not breaking. - ChrisH [more]
Unread 02-03-2004, 18:27
occra 23.
AKA: ryo
None #1481
Re: nonweight and usable
thanks everyone, we'll prolly use lexan then.. if i can find any..
Originally Posted by Greg Perkins
also, to prevent ball running overs, take some 1/4" lexan and use a heat gun to bend it then screw it to your chassis where the balls are likely to come into contact, the bent lexan will actually shoot a ball away when it is hit.
really? the balls are quite grippy. and what if its not bent?
Unread 02-03-2004, 19:10
SarahB's Avatar
SarahB SarahB is offline
SarahB has a spectacular aura aboutSarahB has a spectacular aura aboutSarahB has a spectacular aura about
Send a message via AIM to SarahB
Lexan isn't very hard to find, although you'll probably have better luck looking for polycarbonate(the generic name). McMaster-Carr has it available in various thicknesses and sheet sizes. Part number 8574K63 is a 24" by 48" sheet of 1/16" thick Lexan, that should be enough for your purposes. Alternatively, you could find it in any size and thickness by looking under Raw Materials -> Plastics -> Polycarbonate.
If you don't have the money, try asking some nearby teams if they have any extra they could give you. I know lots of teams have extra hanging around and I'm sure they'd love to help out.
Unread 02-03-2004, 22:36
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
since you guys are rookies, i dont know if you will remember in 2002, we used soccer balls. on our bot we installed curved lexan strips on the front and back where our bot had an opening area... when the balls hit it the bounced off. you must make sure that they are close enough to the ground so they too dont run on top of the balls. the 1/4 lexan will be as springy as a spring, so they will just shoot off of it.
lexan is the easiest way to solve your weight issues...but if you have the money, get sheets of carbon fibre. def. a way to go if its a serious weight issue .
ps. carbon fibre sheets are about $80 for a 3x3 sheet..
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
