Re: The top 8 teams will be....
great question,
I see their being 4-5 undefeated teams with the rest of the top 8 with one loss. However I do not believe that this can be truely answered. Mainly because teams play a differant ammount of matches at each regional, and because of the random alliances, you could have 10 teams being undefeated or you may find regionals where no teams are. |
Most teams at all competitions will have 50% wins and 50% losses. There will be a small number of teams with no losses or one loss and a small number of teams with no wins or one win.
I suspect that it is going to be a LOT harder to go undefeated this year than in previous years, where wins and losses didn't matter. Those few undefeated teams on day two of a regional will find that the last couple of matches are "elimination style" difficult. First of all, if you are undefeated, you have to be very mentally tough to win the next match (same as in eliminations). Many of the undefeated teams on day two will be playing "not to lose" instead of playing "to win." Secondly, teams opposing undefeated teams are likely to experience rather a lot of tactical and engineering support from teams with one loss, whose only way to move up the rankings is for undefeated teams to lose. Consequently, I predict that the top eight will consist of: 0-2 teams that are undefeated 0-4 teams with one loss/tie 4-8 teams with two losses/ties (decided by ranking points) 0 teams with three or more losses/ties |
And one more thing...
I think matches will end in ties more frequently than in past years. There will be a lot of matches that do not have either a capper robot or a hanger robot. Or have such robots that do not successfully accomplish that objective. I think this will be true in the majority of all matches (75 out of 100). Those matches will be decided by the small balls. Many of the small ball matches are going to play out as a shooting contest between the two alliances. I think the likelihood that alliances in these situations will be evenly matched are high. Which means that the final score will be determined by probability rather than skill. In other words, in the matches where teams are evenly matched as to ball delivery and shooting and in which no successful capping or hanging strategy is available, the tendency will be for the match to end in a tie. I think 50 out of 100 matches will have this equilibrium. Since a small perterbation about this equilibrium (1 10 point ball or 1 extra hit or miss) will tip the balance into a win for one team, all 50 of these matches are not going to end in a tie. However, 10-20 will. |
This is a good question. It got me to thinking. As a result I did a quickie simulation of a tournament to answer the following question:
What effect does random Alliance Partners and Opponents have on the record of an individual team? The simulation assumes that the number of teams is large with respect to the number of seeding matches (i.e. I don't have to worry about the affects of teams playing against eachother). It also neglects ties. I basically broke teams up into quartiles in terms of capabilities. I drew random teams out of a hat, determined which alliance won based on which quartiles the teams on the alliances were from. From this, I was able to estimate what percentage of matches teams from each quartile would win*. ANYWAY, I get these results: 1st quartile teams win about 23% of their matches 2nd quartile teams win about 41% of their matches 3rd quartile teams win about 59% of their matches 4th quartile teams win about 77% of their matches Again, my simulation is very rough, does not take into account a lot of stuff and is intended mostly to account for the effects of random alliance partners. The implications of the above data is that with 80 team per division in Atlanta, and assuming 8 seeding rounds, there should be between 2 and 3 undefeated teams and between 7 and 8 teams with only 1 loss. So... I make the following predictions for Atlanta:
Joe J. * This is how my model determined which alliance pair would win the match: The model gives each team in a match a point total associated with the quartile they are in (0-25%tile teams get 1 pt, 25-50%tile teams get 2 pts, 51-75%tile teams get 3 pts, 76-99%tile teams get 4 pts). An alliances score is the sum of points in their alliance (a 52%tile team and 76%tile team would "score" 7 points). In the event of a tie score, an alliance wins half of the time and loses half of the time. This is not a perfect win/loss scheme, but if you figure out what teams win which matches, it roughly seems to make sense to me. Last edited by Joe Johnson : 06-03-2004 at 22:18. |
I think 4%-6% of the teams at any regional or nationals division will stay undefeated. This means that a regional with 50 teams will have 2-3 undefeated teams, while a nat division with 80 teams will have 3-5. Also, at smaller regionals it will tend towards the 4% and at larger events it will tend toward 6% due to the lower number of matches. The rest of the 8 will be one-loss teams with maybe a 2-loss team sneaking in.
I think this year there will be a larger deviation in winning percentages, because the dominant teams will win at all costs rather than keeping the score high and risking a loss, like last year (remember collusion?). In fact, I believe it will be common place for the one-loss teams to have higher Ranking Scores than undefeated teams. This will happen because strong teams that lose a match early in the tournament will desperately try to inflate their Ranking Score, while undefeated teams will adopt a Lombardi philosophy: "Winning isn't everything, it's the only thing." |
#7
I think this depends on when the regoinal is played. The first regoinals, everyone is still figuring out how to play the game. There will be much more luck involved, so I would expect to only see one or two, if any, undefeated teams. However, at the later regoinals and at nats, teams will have figured out the best way to play the game. The luck will be replaced with strategy, and whoever has the better strategy will win. So these competitions may have 4-8 undefeated teams.
#8
Well, data from two regionals this week.
2 teams were undefeated at Annapolis the top teams at UTC had 2 losses each, and the 8th seed had 3 losses 1 team was undefeated at NJ Anyone know for any other regionals? |
#9
I don't remember the exact rankings from GLR, but we finished second with one tie. The team ahead of us was the only undefeated team at the regional.
#11
At SBPLI the top seeded team was 9-1-0, 2 was 8-2-0 and so was 3 and 4
#12
I have stopped trying to guess this. As a driver, all i try to do is go undefeated. That is my only mindset. If you are the only team with an undefeated reckord you are number 1 regardless of qp's. The number of teamsn that go undefeated is impossible to tell with 100% accuracy. Variables include whn the regional is played, who is at the regional, the stategy involved, and many others. Some places have undefeated, some don't. Just shoot for the top. I don't know the # but you guys can keep guessing. Try to speculate for Philly we(222) will be there next.
See ya then!! |
#13
At Pacific NW Regional:
In ranking order: No undefeated 1. 492 - 1 Loss 2. 1359 - 1 loss 3. 360 - 1 DQ, 1 tie 4. 948 - 2 losses Well, I stopped looking after my team ![]() |
| QUESTION OF THE WEEK!!! [11-11-01] | Ken Leung | Rumor Mill | 25 | 22-11-2005 17:00 |
| Overall stats for ALL teams that attended the Championship Event in 2004. | Elgin Clock | Championship Event | 3 | 15-10-2004 18:39 |
| One-Regional versus Multi-Regional teams | Natchez | Regional Competitions | 25 | 20-04-2004 20:40 |
| "Fixing" matches | Shawn60 | General Forum | 158 | 18-03-2003 18:41 |
| Multiple Regionals | archiver | 1999 | 55 | 23-06-2002 22:26 |
