Go to Post We build because we can. - Danaca [more]
Unread 03-03-2004, 12:26
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: Why not analog sensors??
Originally Posted by gnormhurst
I am frustrated by the nearly exclusive use of digital sensors in the kit -- sensors that output either 1 or 0. The Banner sensors are like that, and the IR sensors in the trackers are like that. Why not analog?
You're free to sample the ones and zeros with an A/D as they zip in .
Some may think that "1" or "0" is a much cleaner, noise-free signal than an analog signal, but it is nearly information-free as well!
You're kidding, right?
...But if each tracker's IR sensor put out an analog value proportional to the "brightness" of the IR it was seeing, then small pointing errors could be determined as the difference between the values, without having to hunt back and forth with the servo. Integrate the sensor difference and apply to the servo -- or something like that.
How would you discriminate against all of the other sources of 940nm infrared? Would you use a different wavelength for the other beacon?
If two analog line sensors were pointed, "defocused", at the left and right edges of the line such that the output was a measure of how far off the edge the sensor was, then, again, the small error signal would be the difference of the sensors. Negative means "too far left", positive means "too far right", and zero means right on.
There's nothing preventing you from doing this. Radio Shack carries infrared phototransistors.
Yes, the outputs would have some noise in them -- that's part of the fun, filtering out the noise.
*sigh*
-Kevin
Kevin Watson
http://kevin.org
Interrupts and rotation sensors kor Programming 3 12-02-2004 11:05
Harmful side effects with current sensors m0rph3us Electrical 2 11-02-2004 07:31
wiring diagram for light sensors??? pagemauck Control System 1 21-01-2004 16:32
what type of sensors are good and convenient magical hands Programming 7 04-01-2004 23:04
Q&A Discuss: Optical sensors with EduBot CD47-Bot Extra Discussion 2 01-03-2003 18:37
