Go to Post Because, y'know, FIRST can't make it easy for us. - WinterPoet [more]
Unread 03-03-2004, 09:13
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: Chief Delphi (#47)
Unread 03-03-2004, 09:16
Rich Wong Rich Wong is offline
NYC FIRST Planning Committee Member
no team (NYC FIRST)
Rich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond repute
Send a message via AIM to Rich Wong
Re: pic: Chief Delphi (#47)
Excellent Idea- lifting the robot up, and retracking the arms after hooking?
Are those re-enforcement plates behind each wheel I see?
BTW- You had time for TWO BOTS! wow.
popularis de ob instinctus agnitionis scientia technologia
Home website: www.nycnjfirst.org
Member of NEMO & e^(i*pi)+1 Fraternity.
Member of Friends of Robots
Member of NYCFIRST Planning Committee
Unread 03-03-2004, 09:30
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Actually, we don't need to use these ramps/bumpers for hanging. In this picture, the robot is more or less in its "debug" mode where be can run the wheel motors without driving around.
Although, it DOES give us a capability to reach an extra 8 inches or so. Perhaps it will allow us to reach the bar from different parts of the field? Who's to say... ;-)
Those are the sprockets behind the wheels.
As to 2 robots, I have said elsewhere that FIRST has forced teams that want to be competitive during autonomy to build two. This is why I think autonomy is a bad idea, but FIRST has its reasons.
Joe J.
Unread 03-03-2004, 16:11
Descartes's Avatar
Descartes Descartes is offline
Team Philosopher
AKA: Ryan
#0378 (Circuit Stompers)
Descartes has a little shameless behaviour in the past
I dunno. We had probably the best autonomous at Nationals last year, at least until the last match. We never had the time or cash to build two robots. We just don't use crazy complicated autonomous coding.
"The longer one holds on to a memory... the longer one lives in the past. The deeper the memory they hold onto is... the more beautiful the past will become. The beautified memories will eventually turn into hate... Even if they look ahead, they lose the ability to walk. As long as the heavy chain called Revenge continues to fetter the heart. As long as the tears of sadness continue to flow."
"Dangerous toys are fun, but you could get hurt!"
"The Deadly Dodgeball Head! A simple technique to hold the ball in place with intense suction! Try this at home kids!!"
"I am known as Valentinez Alkalinella Xifax Sicidabohertz Gombigobilla Blue Stradivari Talentrent Pierre Andri Charton-Haymoss Ivanovici Baldeus George Doitzel Kaiser III. Don't hesitate to call."
Unread 03-03-2004, 17:08
AKA: Dr. Joe
FRC #0088 (TJ2)
Originally Posted by Descartes
...We had probably the best autonomous at Nationals last year...
Wasn't at Houston last year, so I can't comment with first hand knowledge, but I don't think that this statement would hold up to a popular vote of those that were there.
More importantly, my continued point is not that teams cannot possibly make a competitive robot with out making two robots, IT IS POSSIBLE. Is it likely? I think not.
Here is an analogy: Is it possible that a team than uses nothing but wood and glue for their robot makes a competitive robot? Yes, it is possible. Is it as likely to as a team with assess to aluminum and welding? Definitely not.
I mean no insult to teams that don't build a second robot. My point is that FIRST needs to really think about what they are doing with the autonomous mode. The proof of the pudding is in the tasting. I would guess that prior to last year, fewer than 1 team in 20 made a substantially identical 2nd robot. Last year, I suppose that number jumped to something like 1 in 10. This year, I suppose that number is closer to 1 in 5.
I cannot stress enough how strongly I feel that this is not good for FIRST in the long run. It is a waste of resources, it stretches out the season, it wears out the worker bees on the teams and it adds very little if anything to the mission of FIRST.
Autonomous mode should be removed. There I said it and I am not sorry.
Joe J.
Unread 03-03-2004, 17:24
Tyler Olds Tyler Olds is offline
FUN Show Host
no team (First Updates Now)
Tyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond repute
Originally Posted by Joe Johnson
Wasn't at Houston last year, so I can't comment with first hand knowledge, but I don't think that this statement would hold up to a popular vote of those that were there..........
........Autonomous mode should be removed. There I said it and I am not sorry.
Joe J.
Very good post Joe:
First off, I believe that a couple other teams had a pretty good auto mode (if you have seen 111's you would know what I mean).
I am personally against auto mode my self. This puts rookie teams at a disadvantage because it is just another variable that they have to worry about.
It also can make those first 15 sec pretty boring to watch. Last year at regionals I would say 1 in 2 teams didn't have an auto mode (though I would expect a better ratio this year).
Also this can set the teams who have the best engineers in the world apart from teams who have no engineers or whose engineers are not skilled in that field. Once again I am going to relate to Wildstang. Their auto mode was incredible, however there was no way that our team could have done something like that last year.
To get back on subject, those "stilts" that you have are a very versitle tool that will give you a huge advantage, great job!
First Updates Now Show Host.
Watch and Listen to FUN on Youtube, iTunes, and www.firstupdatesnow.com
FRC Emcee 2009-2016: Team 2826 Wave Robotics Lead Mentor 2001-2004 Team 93 NEW Apple Corps Alumni
CD Moderator
Unread 03-03-2004, 17:44
AKA: Dr. Joe
FRC #0088 (TJ2)
I am an idiot...
I really am an idiot some times...
I am sorry, I really need to try to contain myself. I would just delete my comments about autonomous mode, but since they can be interpreted as painting a less than flattering picture of myself, I would feel sort of like a cheater by removing them -- leaving them up is sort of like doing penance.
Here is the thing: I should not have brought up my opposition to autonomous mode AGAIN and certainly not in this thread.
If you feel compelled to continue the topic, I will not stop you, but I ask that you please start a new thread on the topic rather than continuing it in this thread. Feel free to "quote" my text but let's keep in in another thread.
Actually, I propose that we just let the thing dye until after the Championships in Atlanta. As for myself, I will try to contain myself until then, unless provoked, I will just let it go.
Sorry again.
Many regrets,
Joe J.
Unread 03-03-2004, 18:23
Dima Dima is offline
Dima is just really niceDima is just really niceDima is just really niceDima is just really niceDima is just really nice
Send a message via AIM to Dima
ok lets see
looks like you decided to not use any pneumatics this year.
2 atwoods for the drivetrain
2 drills for the arm. one to move it up and down the "main post" the other to rotate it (with help of surgucal tubing?)
1 vandoor to rotate the "stilt" made out of diamond plate
I like the "stilts" one to lift the front up the 1' platform and the other to life the back and roll untill the robot is mostly up on the platform
the rest a guesses
it does look like from the pictures that you have a second vandoor to move the "stilt" on the side of the ball mecanism. But I didnt think that a second vandoor was allowed so i am probably wrong on that
ether 2 Globe motors or 2 FP's to open,close the claw (by having 2 you are able to move across the bar while hanging)
whatever is left for the ball mechanism.
Very surprized that the ball chute/tube doesnt extend up any higher (or does it? )
all in all looks like a very nice robot, with quite a few capabilities. Looking foward to seeing it in person in San Jose
Unread 03-03-2004, 22:10
Korbin's Avatar
Korbin Korbin is offline
FRC #1011 (CRUSH)
Korbin is an unknown quantity at this point
Send a message via AIM to Korbin
It looks like the middle pair of wheels are a bit lower, am I seeing that right?
Unread 03-03-2004, 22:35
ofcourse it is that makes the robot turn without bouncing, kingman and cheesypoofs did the same thing.
i think that supporting the wheels just on one side should be the trend from now on, saves weight and makes for a larger footprint
Unread 03-03-2004, 22:44
Josh Fritsch's Avatar
Josh Fritsch Josh Fritsch is offline
Team 27 Mentor/Alumni
FRC #0027 (Team Rush)
Josh Fritsch has a spectacular aura aboutJosh Fritsch has a spectacular aura about
Team 27 also did the same thing. By putting the center wheels down about 1/16-1/8 inch below the rest, it allows for "on a dime" turning ability. This allows the front/rear wheels "teater" on the center wheel making the friction to the floor from the other wheels as minimal as possible.
Unread 03-03-2004, 22:45
oh, btw very nice robot 47, cant wait to see it in action. Which regionals are you guys going to anyhow?
Unread 04-03-2004, 11:39
AKA: Dr. Joe
FRC #0088 (TJ2)
Detroit in week #3, San Jose in week #5, and Championships in week #7.
Joe J.
Unread 04-03-2004, 20:12
PEKMAN's Avatar
PEKMAN PEKMAN is offline
Alum
AKA: Peter Krasucki
FRC #0293 (Spike)
PEKMAN is on a distinguished road
I noticed that today very few teams had working autonomous routines. Most simply stayed in place and waited for the time to expire.
Most of the other teams rode around until they crashed into something.
Maybe tommorrow the situation will improve.
Unread 04-03-2004, 21:48
FUN Show Host
What does this have to do with this thread??
Am I missing something?
CD Moderator
pic: Chief Delphi (#47) CD47-Bot Robot Showcase 13 03-03-2004 11:36
Thank you to Brandon and Chief Delphi Ken Leung Thanks and/or Congrats 19 15-12-2003 22:24
pic: Visioneers and Chief Delphi (1) CD47-Bot Extra Discussion 3 14-03-2003 15:09
Chief Delphi Climbs to New Heights ;-) archiver 2001 0 24-06-2002 04:07
Chief Delphi Institute for Better High School Robotics archiver 2000 0 24-06-2002 00:17
