Go to Post "Everything is possible. Just depends on how much it costs and how much physics you have to apply..." - Kimmeh [more]
Unread 03-03-2004, 17:41
Allison Allison is offline
AKA: Allison Phelps
FRC #1024 (Kil-A-Bytes)
Allison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant future
EDU Bot Power
can you power the edubot controller off the 7.2v battery charger without harming the controller
Unread 03-03-2004, 18:10
jacob_dilles's Avatar
jacob_dilles jacob_dilles is offline
AKA: theshadow
FRC #0620 (WarBots)
jacob_dilles will become famous soon enough
Send a message via AIM to jacob_dilles
Re: EDU Bot Power
i WOULDENT try that. the charger is ment for NiCaD batterys. they recharge slowly. its also probably sevral volts above 7.2. what i would reccomend is going out to your local radio shack and getting a 7.2 v NiCaD, (it wont fit, we already tryed) and using aligator clips to connect it. at least temporarly
"You're not a real programmer until all your sentences end with semicolons;"
Unread 03-03-2004, 18:17
SarahB's Avatar
SarahB SarahB is offline
SarahB has a spectacular aura aboutSarahB has a spectacular aura aboutSarahB has a spectacular aura about
Send a message via AIM to SarahB
Re: EDU Bot Power
If you want to use that battery for normal operations, just buy the connectors from Innovation FIRST.
Unread 03-03-2004, 19:05
Venkatesh Venkatesh is offline
FRC #0030
Venkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to behold
Re: EDU Bot Power
I haven't used the Battery Charger meant for the 7.2V but from what I know about battery chargers, it is not a good idea. Battery chargers output a significantly higher voltage than the battery-to-be-charged. This is so that the battery can be charged. =)
I think that the EDU controller will have a voltage regulator inside (I hope), and if so you might be able to get by with the charger. It would be far eaiser IMHO to get a 7.2V wall-powered transformer. They are quite common.
Good luck.
-- vs, me@acm.jhu.edu
Mentor, Team 1719, 2007
Team 30, 2002-2005
Unread 04-03-2004, 07:16
Re: EDU Bot Power
Allison,
You should never use a battery charger to power critical circuitry. All battery chargers are different in operation depending on the battery they are meant to charge and the method used to charge. NiCad batteries like to be constant current charged, that means that the charger is never putting out 7.2 volts except when it is connected to a fully charged 7.2 volt battery. Nicad chargers frequently output large current spikes and switch in a load resistance periodically to measure the battery condition. Bottom line is a charger is not a power supply. Between the controller and the devices you have connected to it, you have a big investment. Don't sacrifice you system.
Unread 04-03-2004, 19:53
AKA: Allison Phelps
Re: EDU Bot Power
thank you everyone,
i was pretty sure it wasn't a good idea that is why i didn't do it but i need to find a way to test autonomous mode because as of right now our robot spins at top speed
Operator Interface power ISSUE kacz100 Technical Discussion 11 27-02-2004 13:46
URGENT!! Need OI power brick specs for 7AM demo tomorrow!!! kmcclary Electrical 8 10-10-2002 10:56
rumor has it that we'll be using IT to power our bot in 2002 archiver 2001 6 23-06-2002 23:22
power of globe motor with gear box? Ken Leung Motors 5 21-11-2001 13:43
Max mechanical power of motors, how is it useful? Ken Leung Motors 1 09-11-2001 14:15
