Go to Post Sally Ride says role models are needed - that's you. - JaneYoung [more]
Unread 03-03-2004, 23:04
ebmonon36's Avatar
ebmonon36 ebmonon36 is offline
AKA: Eric Bredehoeft
FRC #1018 (Robodevils)
ebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud of
Send a message via AIM to ebmonon36
Media player problem
I've got a little problem with Windows Media Player and am running out of things to try so I thought someone here could help. When I want to play a CD, the animation thingy works, but no sound. It works fine for audio already on my computer. I can open up any other player and they will play cd's just fine. I've reinstalled it already and yes, the speakers are on and the volume is up . Anyone have any ideas?
Eric
Unread 04-03-2004, 12:17
David the bomb's Avatar
David the bomb David the bomb is offline
David the Bomb
AKA: David Freitag
#0330 (Beach Bot)
Team Role: Driver
David the bomb is on a distinguished road
Send a message via AIM to David the bomb Send a message via MSN to David the bomb Send a message via Yahoo to David the bomb
Re: Media player problem
I just went on to WM and tried one of my CD's out. It didn't work either. Then I went into Musicmatch Jukebox, and I saw the the volume was way down there. I then went back into WM and then it worked. Try that
^My car
999: 1. Xerox Creativity Award, Silicon Valley Regional
2000: 1. Finalist, Silicon Valley Regional
2001: 1. Winnner, Southern California Regional 2. Xerox Creativity Award, Silicon Valley Regional
2002: 1. Winner, Southern California Regional 2. Johnson and Johnson Sportsmanship Award, Southern California Regional 3. Kleiner Perkins Caulfield and Buyers Entrepreneurship Award, Silicon Valley Regional
2003: 1. Finalist, Arizona Regional 2. General Motors Industrial Design Award, Arizona Regional 3. Regional Chairman's Award, Southern California Regional
2004: 1. Winner, Arizona Regional 2. Regional Chairman's Award, Arizona Regional 3. Finalist, Southern California Regional 4. Judges Award, Atlanta National
Unread 04-03-2004, 18:04
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
You should make sure all volume controls are not muted or turned down low. There may be several volume controls. You mentioned you turned up the one in Media Player and on the computer but I would also go into the control panel and you should have a folder labeled "Sounds and Audio Devices" and in there click on the "Audio" tab and make sure nothing is muted or turned down. It is also possible if you have more than one player another one is or has overiden the settings for Media Player. I've had a similar problem with Real Player. I personally use Media Player most of the time and made it the default player but Real Player kept attempting to be the default until I changed it's settings. Media Player was already the default and when I installed Real Player it set itself as the default and I wound up with two defaults (not even sure how that is possible) and they wound up conflicting each other. So I would say check all the settings for every player you have installed wether it be Media Player, Real Player, Win Amp, Music Match, Quick Time, ect.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
FIRST is missing out archiver 2001 42 24-06-2002 03:54
The problem with scouting... archiver 2001 10 23-06-2002 23:49
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
Human player actions & interactions llambele Off-Season Events 3 12-10-2001 12:51
