Distance timing out
I have a problem. Whenever I try to find distance between two points the robot controller times out due to the square root calculations. We have a coordinate system of approximately 768x1280 units. Do you think a lookup table would be too large?
Re: Distance timing out
square root calculations are the worst
can you leave the number squared and work with it that way? |
How about having it go to, say, 1 decimal point? with such a large system, you don't need it that precise. And the field is 24' by 48'.
Yes, that would be to big for a standard lookup table. That would be almost a megabyte, if you only looked up a single byte. If you were doing it with floats, it would be even bigger.
Here you go. This based on an algorithm I found on Microchip's web site. It is supposedly optimized for the PIC series chips and will always loop 9 times.
//return the square root of an unsigned 16 bit integer
//based on sample from microchip.com
unsigned int Sqrt16(unsigned int val)
unsigned int mask = 0x100;
unsigned int result = 0x80;
while (mask > 0)
if ((result * result) > val)
result &= ~mask;
mask >>= 1;
result |= mask;
return result;
Sorry, I wasn't paying attention. You need a 32-bit version: Code:
//Return the square root of value x where x is an integer. This
//is based on the fast square root algorithm from microchip.com.
unsigned long sqrt32(unsigned long x)
unsigned long mask = 0x1000;
unsigned long result = 0x800;
while (mask > 0)
if ((result * result) > x)
result &= (~mask);
mask >>= 1;
result |= mask;
return result;
| Timing of nats for next year | Ian W. | Championship Event | 13 | 03-03-2003 18:28 |
| optimum sensing distance for sensors | DaveG702 | Electrical | 3 | 31-01-2003 22:06 |
| what is or isn't a timing belt? | archiver | 2001 | 6 | 23-06-2002 23:26 |
| two sided timing belt | archiver | 2001 | 3 | 23-06-2002 22:34 |
| Dual Sided Timing Belts | Lachuck894 | Technical Discussion | 9 | 14-01-2002 10:10 |
