Go to Post When I invite a woman to dinner, I expect her to look at my face. That's the price she has to pay. - dlavery [more]
Unread 04-03-2004, 19:16
bludstayne's Avatar
bludstayne bludstayne is offline
bludstayne has a little shameless behaviour in the past
Send a message via AIM to bludstayne Send a message via Yahoo to bludstayne
Distance timing out
I have a problem. Whenever I try to find distance between two points the robot controller times out due to the square root calculations. We have a coordinate system of approximately 768x1280 units. Do you think a lookup table would be too large?
I hate signatures. I wouldn't even consider having one.
Unread 04-03-2004, 19:21
Re: Distance timing out
square root calculations are the worst
can you leave the number squared and work with it that way?
Unread 04-03-2004, 19:29
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
How about having it go to, say, 1 decimal point? with such a large system, you don't need it that precise. And the field is 24' by 48'.
Unread 05-03-2004, 11:16
Yes, that would be to big for a standard lookup table. That would be almost a megabyte, if you only looked up a single byte. If you were doing it with floats, it would be even bigger.
Unread 05-03-2004, 12:04
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
Here you go. This based on an algorithm I found on Microchip's web site. It is supposedly optimized for the PIC series chips and will always loop 9 times.
//return the square root of an unsigned 16 bit integer
//based on sample from microchip.com
unsigned int Sqrt16(unsigned int val)
	unsigned int mask = 0x100;
	unsigned int result = 0x80;
	while (mask > 0)
		if ((result * result) > val)
			result &= ~mask;
		mask >>= 1;
		result |= mask;
	return result;
<edit>
Sorry, I wasn't paying attention. You need a 32-bit version:
//Return the square root of value x where x is an integer. This
//is based on the fast square root algorithm from microchip.com.
unsigned long sqrt32(unsigned long x)
	unsigned long mask = 0x1000;
	unsigned long result = 0x800;
	while (mask > 0)
		if ((result * result) > x)
			result &= (~mask);
		mask >>= 1;
		result |= mask;
	return result;
</edit>
Unread 05-03-2004, 13:47
Originally Posted by bludstayne
I have a problem. Whenever I try to find distance between two points the robot controller times out due to the square root calculations...
Do you actually need to compute the square root, or can you do what you need to with the square of the distance? For instance, if you're comparing the distance to a constant value, you can change the constant to be the square of what it would otherwise be.
Timing of nats for next year Ian W. Championship Event 13 03-03-2003 18:28
optimum sensing distance for sensors DaveG702 Electrical 3 31-01-2003 22:06
what is or isn't a timing belt? archiver 2001 6 23-06-2002 23:26
two sided timing belt archiver 2001 3 23-06-2002 22:34
Dual Sided Timing Belts Lachuck894 Technical Discussion 9 14-01-2002 10:10
