Go to Post All tools are powered by magic angry noise. - artdutra04 [more]
Unread 04-03-2004, 14:58
HuskieRobotics HuskieRobotics is offline
HuskieRobotics has a little shameless behaviour in the past
Exclamation Why doesn't this work??!??!!?!!!?!?
I am using the following code to make our robot follow the line but it won't build and i was wondering if anyone could help me out cuz i am frantic...
void User_Autonomous_Code(void)
while (autonomous_mode)
if (statusflag.NEW_SPI_DATA)
Getdata(&rxdata); // bad things will happen if you move or delete this
// Autonomous code goes here.
digital_io_1 = 1;
if(rc_dig_1 ==1 )
pwm13 = 137 pwm14=100;
else
pwm13 = pwm14 = 140;
if(rc_dig_2 == 1)
pwm13 = 100 pwm = 137;
else
Generate_Pwms(pwm13,pwm14,pwm15,pwm16);
Putdata(&txdata); // even more bad things will happen if you mess with this
Thanks!!!!
Unread 04-03-2004, 15:11
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: Why doesn't this work??!??!!?!!!?!?
Could you copy the output from the failed build here? I think your problem is missing a few closing brackets, but it's hard to tell. The output should make it very easy to solve.
Unread 04-03-2004, 15:12
Exclamation Re: Why doesn't this work??!??!!?!!!?!?
sure can here it is:
Deleting intermediary files... done.
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 "ifi_startup.c" -fo="ifi_startup.o" /i"C:\MCC18\h" -D_FRC_BOARD -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 "ifi_utilities.c" -fo="ifi_utilities.o" /i"C:\MCC18\h" -D_FRC_BOARD -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 "main.c" -fo="main.o" /i"C:\MCC18\h" -D_FRC_BOARD -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 "printf_lib.c" -fo="printf_lib.o" /i"C:\MCC18\h" -D_FRC_BOARD -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 "receiver.c" -fo="receiver.o" /i"C:\MCC18\h" -D_FRC_BOARD -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 "tracker.c" -fo="tracker.o" /i"C:\MCC18\h" -D_FRC_BOARD -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 "user_routines.c" -fo="user_routines.o" /i"C:\MCC18\h" -D_FRC_BOARD -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 "user_routines_fast.c" -fo="user_routines_fast.o" /i"C:\MCC18\h" -D_FRC_BOARD -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
H:\Working on it\Robot\frc_tracker\user_routines_fast.c:201:Erro r: syntax error
Halting build on first failure as requested.
BUILD FAILED: Thu Mar 04 15:15:45 2004
hope that it will help you to help me!!
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Thanks!!!!
First, use the [code] tag.
At line 14, use } instead of { (I asume that was a copy error).
Where is the error? double click it in the build window to see. (line 22, probably)
If you're using the yellow Banner sensors, what wire are you connecting to the FRC? And, compared to the line, are far apart are they?
Unread 04-03-2004, 15:16
That was not the error because when i fixed it i still get the same error and i do not know where the error is but i wish that i did!!!!
Unread 04-03-2004, 15:17
Here are a couple of corrections.
//		 digital_io_1 = 1; /* Belongs in User_Initialization */
			if(rc_dig_in01 ==1 )
				pwm13 = 137;
				pwm14=100;
			else
			if(rc_dig_in02 == 1)
				pwm13 = 100;
				pwm14 = 137;
			else
Unread 04-03-2004, 15:21
Cool Re: Why doesn't this work??!??!!?!!!?!?
YESSSSSSSSSSSSSSSSS!!!!!!!!!!!!!!!!!
thank you!!!!!!!!!!!!!!!!!!!!!!!!!!
Unread 04-03-2004, 15:26
AKA: Jamie Bliss
Sorry, I'm slow!
Which one? line 14 or 22? and what is it now? (or 13? I just found that)
Also, see the pic for what I mean.
Unread 04-03-2004, 15:27
Some people are just so easy to please
Good luck!
Unread 04-03-2004, 15:42
Engineers are easily amused :^)
Unread 04-03-2004, 15:45
Simple minds, simple pleasures
Unread 04-03-2004, 19:09
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
note - you can put multiple commands on the same line if you want - just make sure you still have a semicolon after each command, just as you would if they were on separate lines. semicolons are not line separators, they are instruction separators.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 04-03-2004, 19:23
AKA: Jamie Bliss
So similarly, Can you put 1 command across multiple lines? I mean with the compiler, not the language.
Unread 05-03-2004, 00:20
Computer Guy
AKA: Dav
if it's anything like a normal C compiler, you should be able to. no guarantees, though.
3D Studio Max won't work David the bomb 3D Animation and Competition 3 03-03-2004 17:12
Problems of the mind... effecting work Gadget470 Chit-Chat 20 18-11-2003 11:56
Edit doesn't work on original title posts??? Elgin Clock CD Forum Support 6 12-03-2003 17:30
Who knows how the motors [I]really[/I] work? Wetzel Chit-Chat 5 13-02-2002 21:50
Does anyone on this board work at home depot? mnkysp6353 General Forum 2 30-12-2001 13:27
