Go to Post A dedicated team is a happy team. - sgreco [more]
Unread 04-03-2004, 22:20
Mike8519's Avatar
Mike8519 Mike8519 is offline
FRC #0303 (TEST Team)
Mike8519 is just really niceMike8519 is just really niceMike8519 is just really niceMike8519 is just really niceMike8519 is just really nice
Small ball inflation problem
I dont know if anyone is having the same isues but at the Mid-atlantic regional we are having some serious problems with the size of the balls. Our robot has seperate channels for storing the balls, and have a half inch area of play on each side of a 13" ball. The FIRST balls get stuck in our robot however from being wedged in the sides. When we finally TRIED to stick a couple balls in the small ball sizer they would not fit. They were 1 to 1.5" too large in diameter.
I think this is unacceptable. Unfortunately I believe that at our regional we are the only team to rely on the ball size, so we won't have voice in numbers. I hope this isnt a problem elsewhere. Our Robot won't function correctly without the balls being at spec, or at least within a 3/4 inch size.
And Big Mike, if you are listening, fix the balls, or have some peons do it. I'd do it myself if I was allowed .
Unread 04-03-2004, 22:27
Re: Small ball inflation problem
I would be willing to bet the balls were the proper size when they were inflated, and they were all new so they streached out after a while
I would hope the FIRST crew will check them each morning at least - you are right, I can see a half inch, but not an inch and a half - Im sure other teams that collect and carry them will have similar problems.
Dont be afraid to approach the head ref and talk to him about this - you put a lot of work into your machine, and FIRST did layout some guidelines for variation, I dont think it was that large.
Unread 04-03-2004, 22:28
ErichKeane ErichKeane is offline
FRC #3210
ErichKeane is just really niceErichKeane is just really niceErichKeane is just really niceErichKeane is just really niceErichKeane is just really nice
Send a message via AIM to ErichKeane
At NJ, not only were the balls all the wrong size, we had before the first practice round, 1 ball that was easily double the size of the rest of em. I figure that woulda put a crimp in your mechanics...
Unread 04-03-2004, 22:43
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
Last year, at the first regional my team attended, we found the bins to be wider then we expected- 1 or 2 inches on every dimension.
The ball makers probably do not care if their balls are too big or small. They did not design the balls for space travel, they designed them to be kicked and thrown around a playground; the tolerances on the balls probably aren't very tight. I wouldn't be surprised if the ball manufacturer retools damaged/worn molds by expanding the cavity size (thereby making future balls produced by that mold larger).
FIRST could probably fix the problem by taking pressure out of the balls until they have the correct diameter, but then what about the teams that rely on the balls pressure and not their diameter? It depends on which is specified in the rules.
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
Unread 04-03-2004, 22:45
Mike8519's Avatar
They have a sizing box for inflating them, and the rules state that balls are inflated to size, not pressure.
Unread 04-03-2004, 22:47
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
I have also seen some of the balls I would classify as being oval and not exactly round.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 04-03-2004, 22:58
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
FIRST said the balls would be inflate from 12 to 14 inches. So an inch over isn't too much over. However an inch and a half would be.
Unread 05-03-2004, 22:20
Josh Fritsch's Avatar
Josh Fritsch Josh Fritsch is offline
Team 27 Mentor/Alumni
FRC #0027 (Team Rush)
Josh Fritsch has a spectacular aura aboutJosh Fritsch has a spectacular aura about
This happens every year when FIRST includes a game with balls. We made the mistake in 2002 and had a component that required a very specific ball size and we never got to use it. I guess you just have to count on never having a ball the correct size and design your 'bot that way. Sometimes there is just nothing you can do about it such as in 2000. With all the heat down at nationals in florida the balls were easily bigger than the projected size because of expansion.
Unread 05-03-2004, 22:37
Elgin Clock's Avatar
I'm sorry, but I did not see any 26" 5 or 10 pt balls in NJ....
Unread 06-03-2004, 05:33
FRC #3210
Before the rounds started, the very first practice round, we had on our coral 1 HUGE ball, that looked like if you touched it wrong it was going to pop, and 2 possibly smaller balls. During the first day of competition, they were all almsot perfect from what i saw.
small ball ristrictions aero528 General Forum 2 21-02-2004 22:40
Small ball grabers nuggetsyl Robot Showcase 9 20-02-2004 10:47
Small problem Cadetdan Electrical 1 10-02-2004 15:17
game ball inflation archiver 2000 5 23-06-2002 22:28
Kickoff Workshops......... Small Problem archiver 2001 3 23-06-2002 22:08
