Go to Post If this information is not 100% correct, you should follow the default advice I have for when anything goes wrong: Blame the Programmers - IKE [more]
Unread 05-03-2004, 02:34
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Caltech's DARPA Grand Challenge Entry (Redux)
Fresh pictures of Caltech's DARPA Grand Challenge entry taken today (March 4th) at our ultra-secret test area at one of Santa Anita Racetrack's vast parking lots.
Q: How many computers are needed to autonomously drive a Chavy Tahoe 200+ miles?
A: Six IBM 3.0 GHz Xeon-based PCs running Linux.
-Kevin
Kevin Watson
http://kevin.org
Unread 05-03-2004, 03:25
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Re: Caltech's DARPA Grand Challenge Entry (Redux)
Are those six computers running as a Beowulf Cluster, in one way or another (I'm thinking of a system like MOSIX), or are they all operating relatively independantly, performing seperate tasks? Also, sort of related to the previous question, which Linux distro was chosen to run th[is/ese] system[s]? And finally, I'm curious as to what you're using to power all of the equipment, even though it's a fairly trivial topic.
Also, I like the fire extinguisher mount points. I recently saw an article in PopSci about CMU's DARPA entry, and in the few pictures they had, there were visible many of the large Emergency Stop buttons placed around the vehicle, and I thought of what a simple and effective (one would hope, anyway) way that would be to try to keep safe during development.
Anyway, keep up the great work, and good luck!
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 05-03-2004, 04:06
FRC #2429
It's a bit of a hybrid. One of the students wrote a Message Transport Agent that allows computers to pick-up tasks from another computer if it becomes too busy or fails. Generally, tasks run on one computer.
I'm not sure.
There is a separate 6KW generator that sits where the front passenger seat used to be.
Yes, we have four emergency stop buttons around the vehicle. Testing has been... Um... interesting. Today, one of the team members sent a bad command to the throttle controller and the vehicle took off at full throttle without any warning. It must've hit 40-50 MPH before someone hit the remote kill switch . Last weekend the Tahoe took off at full throttle and pointed itself in the general direction of the film crew that's been following us around. With any luck, we'll get to see it on PBS' Nova in late Spring .
-Kevin
Kevin Watson
http://kevin.org
Unread 05-03-2004, 04:14
-Kevin
Ah. Now I see the buttons. They're a bit less conspicuous on this one than on CMU's.
If you could throw up another thread when you learn when the specific Nova episode will air, I'd personally much appreciate it, as I'm sure many others would.
Also, thank you much for answering my questions.
Unread 05-03-2004, 11:02
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Will your vehicle be at California Speedway on Wednesday? We are stopping on our way to Phoenix to check out the DARPA vehicles.
Unread 05-03-2004, 12:16
FRC #2429
We'll be there at least in the morning. 9:30 - 10:00 is when our second qualifying run will take place. I'm not sure what the policy is regarding letting spectators in the pits, but if you can get in, look me up and I'll show you the vehicle.
-Kevin
Kevin Watson
http://kevin.org
Unread 05-03-2004, 12:35
FRC #2429
[TrashTalk] That's because CMU will need to use their emergency buttons more than we will (once we get the above mentioned bugs worked out )[/TrashTalk]
You can expect a lot of media coverage over the next few weeks. Here and here are articles I just heard about. Newsweek was out a few days ago to interview Dave van Gogh, who is Caltech's DGC program manager. They were there while I was at work, so I missed getting my photo in Newsweek by an hour (sorry Mom). The Newsweek story should run next Monday.
-Kevin
Kevin Watson
http://kevin.org
Unread 05-03-2004, 15:38
Alex Ko's Avatar
Alex Ko Alex Ko is offline
Segway Nut
#0846
Alex Ko is a jewel in the roughAlex Ko is a jewel in the roughAlex Ko is a jewel in the rough
Hey Kevin,
You must be a hardcore engineer to work on a FIRST team *and* the DARPA team!
I used to work with Dave at Applied Materials... was hoping to stop by the quals next week, but work has me stuck in the Bay Area.
Good luck!
-- is one tank of gas enough to get you there?
Unread 05-03-2004, 15:59
Kris Verdeyen's Avatar
Kris Verdeyen Kris Verdeyen is offline
LSR Emcee/Alamo Game Announcer
FRC #0118 (Robonauts)
Kris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond repute
The Red Team (CMU) suffered a pretty severe setback yesterday (3-4) when their vehicle Sandstorm rolled during a software test. There is some speculation that the Modified Hummer's engine was undamaged because one of the stop buttons was hit when it rolled. Now all they have to do is fix everything in a week, and they're set.
I can't wait to see what goes on with the Grand Challenge. Will there be any real-time race coverage, either online or on TV?
...Only a few people are awake and they live in a state of constant total amazement. -JP Shanley, Joe vs. the Volcano
Unread 06-03-2004, 01:35
FRC #2429
I, of course, didn't have any idea that the Red Team had suffered this setback when I made the above wisecrack. In all seriousness, I hope Red can pull things together in time for the QID next week because it'll certainly be less fun without his team competing.
For those that don't know, CMU is a robotics mecca. Most of the really cool algorithms that are used in autonomous navigation were developed by Red and his grad students.
-Kevin
Kevin Watson
http://kevin.org
Meet BOB, Caltech's entry into the DARPA Grand Challenge Kevin Watson Robot Showcase 14 30-12-2003 16:10
