Go to Post Gracious Professionalism is a compass, not a set of calipers. It should be used to guide what you do rather than to measure it. - Alan Anderson [more]
Unread 05-03-2004, 21:37
FadyS.'s Avatar
FadyS. FadyS. is offline
AKA: Fady Samuel
#1246 (Agincourt Robotics)
FadyS. is on a distinguished road
Getting Fancy with Sensors
Hi, we're a rookie team and we're not done autonomous mode, but since we have over 3 weeks until our regional, I'm taking the time to work on autonomous mode. Now, I don't want to go overboard with sensors for autonomous but I want to know what kind of stuff is available at a local Radioshack that may be useful to autonomous. I already picked up a few switches and a potentiometer. I may pick up another potentiometer though. Also, I might pick up a few infrared phototransistors. Are these analog or digial sensors? Any other neat gizmos to pick up? I've got to admit, I love playing around with all these sensors. Hehe, "Captain, sensors are picking up a spatial anomoly! We should shut down the warp drive!!!" lol.
Unread 06-03-2004, 00:15
ejthe4th ejthe4th is offline
Active User
AKA: EJ Meyer
#0240 (Mach Vee)
ejthe4th is on a distinguished road
Re: Getting Fancy with Sensors
our team is using a whole load of sensors for auton_mode =1. one of the first sensors we used is the banner light sensors. they came standard in the kit, they give off a digital signal.
their wiring schematic is on page 18 of section 5 "The Robot". the Blue wire goes to ground, Brown goes to +12V (from a 20Amp breaker on the fuse bus, it does not connect to the +5V on the robot controller). the black and white wires are the signal wires, one is NC (normally closed) and the other is NO (normally open) there is a schematic on the side of the sensor that helps explain it. you should only need to hook up one of the black or white wires, not both (it's your pick). these sensors can tell the difference between light and dark, it will either "see" a light or it won't, nothing between (good for line following to finding a line)
have you tried using the current sensors that are provided in the kit? we've had quite a bit of "fun" testing these...we wanted to know how many amps the motors could pull, so we put the 'bot agains the wall, i climbed on and we went "full speed ahead", the motors got really hot, the wheels slowly spun, burning 2 tread marks into our school's carpeting, and pulling 40 amps per motor...we only tested this once.
if you need any help with these i'll try and help, just e-mail me
Mach Vee Team 240
2004 GLR Semi-Finalist
Captian
Programmer
Electrician
Fabricator
Designer
Unread 06-03-2004, 00:31
JamesWu JamesWu is offline
#0957 (WATSON)
JamesWu has a little shameless behaviour in the past
hahaha... I wish I could have seen it. A Robotics dude climbing onto his poor robot and getting ready to hangon for a wild ride but instead recieving some burnout.
I want to start a revolution. Days and Nights were spent wrestling with the impossiblities of typing a word with only one finger. That word is lol, So....use laf.
Unread 06-03-2004, 10:19
Personally I think the most usefull one you can get is the gyro sensor, it will allowyou to measure if your bot is turning, or how much its turning, or how far its actully turned
I cant imagine doing auton mode without it - most bots, if you turn the motors on, they drift to one side or another, and when you turn its hard to dead recon to a new heading
the gyro resolves all those problems with excellent accuracy
only thing is, its not a simple device to use - but if you have 3 weeks you can get one and play with it on your EDU bot - the best source I found is Avent (electronics distributor) - they had them in stock last time I checked for $50
search on 'gyro' or 'yaw rate' here in CD and you will find several threads on the subject, and how to use them - I think the part number (top of my head) is ADRSX150EB- something like that - its in the other threads.
Unread 06-03-2004, 13:10
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
a small note, apparently the banner sensors distributed in this year's KOP do not have the schematic on the side... last year's did.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 06-03-2004, 20:13
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Yes, And this year's aparently have a better range (Ask Biff).
You pulled only 40 amps? We manged to pull 140.
Unread 06-03-2004, 21:44
FadyS.'s Avatar
AKA: Fady Samuel
Also, anyone know where we can get encoders? What kind of stores do we check at. Also, we do we get extra infrared sensors from? The infrared phototransistors have terrible range.
Unread 06-03-2004, 22:16
Computer Guy
AKA: Dav
Digi-Key sells encoders, you could check with them (chances are Radioshack doesn't have them in stock )
Unread 07-03-2004, 00:44
jamapor jamapor is offline
AKA: Jake
#0190 (Gompei and the Herd)
Team Role: Human Player
jamapor is on a distinguished road
Send a message via AIM to jamapor
We are using an extreme amount of sensors. We have ultra-sonic sensors in the front bumper of our robot to detect distance to the stairs. Then, we have two gyro's to detect X motion as well as Z direction motion. Also, we have light sensor, wheel-encoders to count wheel rotations to sense distance traveled. We have numerous potentiometers and countless limit switches. (over 15). Sensors can be very usefull this year.
Unread 07-03-2004, 12:27
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Our robot is really fairly light on the sensor side. We have some to prevent damaging certain components, but the only other things that we have are two encoders on the wheels. I wish we had more...
I hope that next year they'll let me use the gyros. They'll be much more fun than counting ticks on a stupid encoder.
Unread 07-03-2004, 16:16
AKA: Jamie Bliss
ick up jaw: You have space left for anything? I'm not sure the RC has that many ports on it!
Unread 07-03-2004, 17:13
Random Dude Random Dude is offline
Oregon State Head FTA
AKA: Chris
no team (Oregon Robotics Tournament & Outreach Program)
Random Dude will become famous soon enoughRandom Dude will become famous soon enough
Well, they could be using an external micro for the sensor IO. Thats how I'd do it atleast.. collect and process all the data externally, and just ship it back in a nice neat format to the RC.
That way you don't need to waste cycles on the RC integrating the gyros, and counting the encoders, etc...
Unread 07-03-2004, 17:21
KevinB's Avatar
KevinB KevinB is offline
AKA: Alum
We're having great success with "counting ticks on a stupid encoder".
Unread 07-03-2004, 17:25
jacob_dilles's Avatar
jacob_dilles jacob_dilles is offline
AKA: theshadow
FRC #0620 (WarBots)
jacob_dilles will become famous soon enough
Send a message via AIM to jacob_dilles
not only did we have great sucess, but we can control turning, distance and speed down to 1/4", and its shorter, faster, and simpler then writing a gyrp algortiom. 2 intrupts, 2 banner sesors, 2 wheels, 2 variables. lol thats it.
for next year im working right now on a pic16F84 in basic (yea i know; shush up) to integrate the gyros (2x) 2 banner sensors (for the wheels) and a compass. it will output the data in rs232 format as (speed)-(direction) every time its polled, and a (time)-(distance) may get built it soon. i might might write a white paper on it if i can pass history
edit: once agein, my education is interfering with my schooling
"You're not a real programmer until all your sentences end with semicolons;"
Unread 07-03-2004, 21:21
Programming User
Yeah, it works fine, I just don't like them because of the relative unreliabilty of them. For instance, it's impossible for us to autonomously make it up onto the platform and turn toward the bar because we bounce some. At least with gyros, they don't mess up if a wheel slips or you get hit from the side or something like that.
Anyway, encoders do work.
Why not analog sensors?? gnormhurst Programming 16 07-03-2004 16:14
Interrupts and rotation sensors kor Programming 3 12-02-2004 11:05
wiring diagram for light sensors??? pagemauck Control System 1 21-01-2004 16:32
what type of sensors are good and convenient magical hands Programming 7 04-01-2004 23:04
Q&A Discuss: optical sensors CD47-Bot Extra Discussion 0 15-02-2003 22:58
