Re: Wat the Hook Gon Be?
we have a grapling hook made out of aluminum. It was waterjetted by one of our big sponsors American Aircraft. It comes unattached by Velcro. The actual part of the arm is like folded in with our multiplier ball grabber then when we are ready, (it is srping loaded) the second portion of the arm swings out, we position the hook, pull away, and then let the winch do the rest.
Our hook is made out of carbon fiber. It slips onto the end of a long piece of fiberglass that we retract once the hook is on the bar. It's then connected to the robot by a long piece of Spectra. There's a little catch on the hook that holds it on to the bar. Oh, and we cut it on a band saw.
nothing fancy, a simple caribeaner attached to the bot w/ steel cable....KISS
Our hook was just a piece of 1/4 x 5/8 steel bent with a hammer. It was mounted somewhat oddly - sort of horizontally with the hook part down. It would rub the bar and flip up into position. The cable and tube spring tension was all that held it in place. Crude but effective. We got all 4 robots on the bar in one match. |
Carbon Fiber is allowed this year since there's no ban on exotic materials like previous years. As long as you can account for it in your $3500 limit you can us it.
Our hook is more than just a hook. For those of you who were at the New Jersey regional you know what I'm talking about. It is aluminum tube (1"x1") cut and tig welded together with four 90 degree bends (two per side) that actually make two points to hook on to. Inside these hooks are two rollers, one on each side, connected by a timing belt to each other. This belt and the pulleys ride on the bar. Connected to one of the pulleys is a sprocket and a chain going to another sprocket and a motor on top of the hook. Once the arm is extended with two pneumatic cylinders the hook reaches over the bar and the cylinders are then retracted pulling us up. Now here's the fun part, when another robot goes for the bar, we just activate the motor and our robot still hooked and hanging can move sideways back and forth across the bar to block the opponents chance of hanging. There's a photo of our hook in the "Pics from NJ", the first column second photo down. www.pbase.com/sscamatt/robot...ew jersey day 1 [EDIT] I'm having problems getting the link to work. "jersey day 1" is also part of the link but I can't get it included. If you go to the "General Forum" then to "Pics from NJ" click the link in the first post our robot hook is shown in the first column second pic down. And if anyone knows how to make the link work please let me know.[EDIT] Last edited by Jay H 237 : 07-03-2004 at 10:51. Reason: issue with link |
We definately had the most obvious hook, a CANE! See http://1418.org
(Incedentally, we were complemented on it when we won rookie all-star) |
#7
you can insert "%20" in place of any blanks. www.pbase.com/sscamatt/robot...ew jersey day 1 I visited J&J on Saturday and saw your rolling hook in action. It was very impressive. One match you kept an opponent from scoring by making them place their hook on top of yours. Not supported by the bar= no score. Last edited by Mark McLeod : 08-03-2004 at 12:37. |
#8
Here is our hook. It is made out of 1/2 aluminum round stock. IT is just like a body clip.
The diameter of the opening in the hook is smaller than that of the bar therefore it snaps back around the bar attaching us to the bar. (the only way to get us of the bar is upwards....) here is the link: http://www.tahsroboticsteam.org/Pict...n/100_0712.JPG Last edited by team222badbrad : 08-03-2004 at 12:16. |
#9
Since we had the weight luxury, we went ahead and made our hooks from 1/4 inch thick 1 & 1/4 wide steel barstock. The hooks probably weigh in, at most, about a pound a piece and have 1/8 thick sheet latex glued on to improve grip. They are mounted at the mid-section of our plow/ball grabber with two or three 1/4-20 bolts
We made it by cutting the steel with a reciprocating saw, cold forging it with a hammer, and then radiused it around a pipe. (Yes it was hard to do) |
#10
http://www.pbase.com/image/26627878 And look, in the background!! Itsa ME!! Before I shaved my beard, and still with hair (which may change by next week cause of a bet I made with the team...) Edit: A link would be nice to include! :-D Edit 2: A working link, that is... Last edited by Elgin Clock : 08-03-2004 at 16:36. |
#11
We made ours outta steel 3/8" bar stock. We then bent it on the 'ol brake. Looks like it was made by Jesse James himself. It is kinda the shape of the top of a pimp cane.
#12
our 2 hooks ( 6" apart ) are 1/8" alluminum plate. they were originaly 2 1/4" plates, but we reduced it to save weight. we cut them on the band saw
i cant believe it actualy holds the weight of the robot, but it does.... |
| Whos gonna be in Double Tree in Houstin | BoticsPUNK | Championship Event | 9 | 08-04-2003 03:48 |
| I'm gonna have to start hangin out with you guys/gals | archiver | 2001 | 4 | 23-06-2002 23:39 |
| What's gonna happen to the seniors??? | archiver | 1999 | 12 | 23-06-2002 22:52 |
| tommorow is gonna be judgment day | Greg Perkins | Off-Season Events | 0 | 14-06-2002 10:45 |
| Batttery hook up | piconysm | Technical Discussion | 3 | 17-01-2002 18:21 |
