Go to Post You know you're addicted to FIRST when you text your mentors more than your friends from school. - LindsayC [more]
Unread 06-03-2004, 19:17
Greg's Avatar
Greg Greg is offline
FRC #1075 (Sinclair Sprockets)
Greg is on a distinguished road
Send a message via ICQ to Greg Send a message via MSN to Greg
Printf Question
This is probably a dumb question but I dont have as much experience with C as I'd like to Is it possible to printf a char as an ASCII character? printf_lib.c says %c is unsupported. But somehow strings enclosed in quotation marks print with no problems. How do I convert a byte to a single-character string?
Unread 06-03-2004, 19:23
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
Re: Printf Question
try creating a 1-element char array, and then assigning the value of the byte to the first element (element 0) in the array.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 06-03-2004, 20:12
Greg's Avatar
Re: Printf Question
Unfortuately, this does not seem to work. I get some garbage as output and then the RC locks up. Could you post some example code?
And, actually, this is not really critical Its ok if I dont get it working.
Unread 06-03-2004, 22:10
Computer Guy
AKA: Dav
Re: Printf Question
last i looked, there were functions to output individual bytes and other things to the output window... try the PrintString() function defined in ifi_utilities.h/c
Unread 06-03-2004, 22:59
Daniel Daniel is offline
Daniel Katanski
#0240
Daniel is on a distinguished road
Re: Printf Question
If you read the file "printf_lib.c" (I think) you will see a comment that says "%c" is not supported. The best you are going to do is put the character into a char array two long setting your character in location 0 and '\0' (or zer0) in location 1, then print it using "%s" as the format and using the array name.
char t [2];
t [0] = 61; // Or what ever you character is.
t [1] = '\0' // Null character.
printf ("%s\n", t);
Unread 07-03-2004, 00:22
Computer Guy
AKA: Dav
Re: Printf Question
char t [2];
printf ("%s\n", t);
yeah, try that... forgot about the null terminator, because i'm so used to just using strcpy gotten lax.
Unread 07-03-2004, 13:43
Greg's Avatar
Re: Printf Question
I actually figured this one out on my own last night Sorry forgot to post here.
Unread 07-03-2004, 21:24
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: Printf Question
What was the fix, anyway? I like to know so that if I ever get it, I have an idea on what it might be.
Unread 08-03-2004, 01:06
Greg's Avatar
Re: Printf Question
Actually, the byte array thing worked on MS VC6.0 but didnt in MPLAB One way of sending an unsigned char as an ascii character is actually very simple. I just do what printf_lib.c does when sending a byte - assign the unsigned char to the transmit register (I think it is called TXREG) and then call WaitForTXEmpty.
Unread 08-03-2004, 06:57
Programming User
Re: Printf Question
Tricky. That interesting. Thanks for that info.
MIM's question of the day on programming. Gene F Programming 3 24-02-2004 16:32
A question about control system options computhief263 Control System 7 04-02-2004 14:46
MnM EASY Question of the Day Winners! Mike Bonham General Forum 22 03-05-2002 21:21
Chief Delphi Site Question Mike Bonham General Forum 1 16-02-2002 22:18
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
