Battery Voltages in Dashboard
With ever more questions about the Dashboard...
![]() I managed to get the two bytes used for the battery voltages to be displayed. Those bytes are nice, they give me a relative idea of how much power I have, but that's not all that useful. I remember last year IFI had a little formula that was in the PBASIC code or the Dashboard spec sheet, I think, but I can't find it. It gave you the battery voltage based off of the binary number the dashboard port outputs. If anyone has that formula, or has devised their own that works, care to share? The only formula I've made is off by too much to be useful . |
Re: Battery Voltages in Dashboard
No Idea, I would assume that either it's tenths of a volt (0 to 120) or it's scaled so that 12v = 255 (254? I'm never sure).
Also, it can't be 12 volts is the same as 254, as that would create huge problems when teams charge their batteries up to 13.6 volts, as my team does every year. Please, if you have no idea as to what I'm asking, don't answer with stupid assumptions that anyone who's dealt with the controllers for more than 5 seconds can shoot down. It wastes time and space, and the community doesn't benefit. I don't go and post answers in the CAD forums, cause I have no idea about CAD, and me posting anything there doesn't help anyone. Anyways, back to the question at hand, does anyone know how IFI set up the battery voltage bytes on the dashboard stream, or have come up with their own way to correctly display voltage? |
I can't, this is my first year in FIRST. And I wouldn't call the answers 'stupid'; they were the end result of simple logic. I have not, however looked at the packets themselves.
Even brightest people do things that occasionally make no sense; considering such ideas, for even a short amount of time, can be benefical. I know: I did Odyssey of the Mind for 6 years before this. Thinking out of the box and considering 'stupid' ideas is never bad. |
I'm not seeing how the page referenced disproves the sugestion. And I do not have the software and the RC together. For our purposes so far, IFI's Dashboard has worked perfectly. I am currently more concerned with autonomous mode right now. If you know the voltage of the battery and the value recieved for 2 different levels, can't you just figure it out? You sound as though you actually have the RC sitting next to you. And personally, if I'm not sure about something like this, I make theories and check them. Those were starting points.
And I do not apreciate these personnal attacks. Good Night. |
#7
This is probably what you're looking for. Straight from ifi_aliases.h
/* Formula to calculate voltage in volts: * current_voltage = battery_voltage * 0.038 + 0.05; */ #define battery_voltage rxdata.rc_main_batt*15.64/256 #define backup_voltage rxdata.rc_backup_batt*15.64/256 |
#9
The formula for previous years was Vin = ((4.7/14.7)* Battery voltage)-0.4
#11
Err. Heh, I think that might work, if I just divide that by 5. A moment of clarity .I'll try that in a little bit, hopefully it works. |
| Why MUST the 7.2v battery be attached to operate servos on the RC? | Mike Rush | Control System | 17 | 06-02-2004 18:57 |
| Quick release battery connector and 120 amps | n[ate]vw | Electrical | 6 | 18-01-2003 23:41 |
| Off-topic battery stuff. | FotoPlasma | Electrical | 4 | 06-01-2003 12:19 |
| Voltage Range of Analog Inputs | Ulibrium | Electrical | 21 | 15-02-2002 14:11 |
| connecting to the battery | ahecht | Technical Discussion | 1 | 25-01-2002 17:15 |
