Go to Post No need to apologize, you didn't do anything wrong. your just learning. thats what the forums are for. please keep them coming. - Tytus Gerrish [more]
Unread 06-03-2004, 20:03
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
Battery Voltages in Dashboard
With ever more questions about the Dashboard...
I managed to get the two bytes used for the battery voltages to be displayed. Those bytes are nice, they give me a relative idea of how much power I have, but that's not all that useful.
I remember last year IFI had a little formula that was in the PBASIC code or the Dashboard spec sheet, I think, but I can't find it. It gave you the battery voltage based off of the binary number the dashboard port outputs.
If anyone has that formula, or has devised their own that works, care to share? The only formula I've made is off by too much to be useful .
AIM --> Woloi
Email --> ian@woloschin.com
Unread 06-03-2004, 20:32
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Battery Voltages in Dashboard
No Idea, I would assume that either it's tenths of a volt (0 to 120) or it's scaled so that 12v = 255 (254? I'm never sure).
Unread 06-03-2004, 20:58
College? What?
It's not tenths of a volt as I'm recieving values too high for that, and why would they waste resolution? Doesn't make sense to use 7 bits in a byte, and leave the other standing alone. Also, look at the old PBASIC code, they have formulas in there which I tried to use, and they went to way above 120, and IFI probably used something similar to those formulas this year, I just can't find it.
Also, it can't be 12 volts is the same as 254, as that would create huge problems when teams charge their batteries up to 13.6 volts, as my team does every year.
Please, if you have no idea as to what I'm asking, don't answer with stupid assumptions that anyone who's dealt with the controllers for more than 5 seconds can shoot down. It wastes time and space, and the community doesn't benefit. I don't go and post answers in the CAD forums, cause I have no idea about CAD, and me posting anything there doesn't help anyone.
Anyways, back to the question at hand, does anyone know how IFI set up the battery voltage bytes on the dashboard stream, or have come up with their own way to correctly display voltage?
AIM --> Woloi
Unread 06-03-2004, 21:08
AKA: Jamie Bliss
I can't, this is my first year in FIRST. And I wouldn't call the answers 'stupid'; they were the end result of simple logic. I have not, however looked at the packets themselves.
Even brightest people do things that occasionally make no sense; considering such ideas, for even a short amount of time, can be benefical. I know: I did Odyssey of the Mind for 6 years before this. Thinking out of the box and considering 'stupid' ideas is never bad.
Unread 06-03-2004, 21:13
College? What?
When ideas can be shown to be incorrect with about 5 seconds worth of research (http://www.innovationfirst.com/firstrobotics) or by simply turning on the robot after fully charging the battery, they're not exactly considered beneficial at all. If you'd like to argue about "thinking outside of the box" you can email me or contact me through AIM (both are in my signature), but stop posting in this thread if that is all you have to say, as I'm trying to figure out how to get the correct battery voltages on the 2004 dashboard, not the benefits of thinking outside the box.
AIM --> Woloi
Unread 06-03-2004, 21:26
AKA: Jamie Bliss
I'm not seeing how the page referenced disproves the sugestion. And I do not have the software and the RC together. For our purposes so far, IFI's Dashboard has worked perfectly. I am currently more concerned with autonomous mode right now. If you know the voltage of the battery and the value recieved for 2 different levels, can't you just figure it out? You sound as though you actually have the RC sitting next to you. And personally, if I'm not sure about something like this, I make theories and check them. Those were starting points.
And I do not apreciate these personnal attacks. Good Night.
Unread 06-03-2004, 21:38
College? What?
I do have an RC sitting next to me, but I only have a 9 volt battery and a 7.2 volt backup battery, neither of which have helped me with reference points, hence the question on the forums as to if anyone else has figured it out. I have no urge to kill the only 9 volt battery I have in my house, just to figure out a formula.
AIM --> Woloi
Unread 07-03-2004, 06:57
Jay Lundy Jay Lundy is offline
Programmer/Driver 2001-2004
Jay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to all
This is probably what you're looking for. Straight from ifi_aliases.h
/* Formula to calculate voltage in volts:
* current_voltage = battery_voltage * 0.038 + 0.05;
#define battery_voltage rxdata.rc_main_batt*15.64/256
#define backup_voltage rxdata.rc_backup_batt*15.64/256
Unread 07-03-2004, 10:13
College? What?
I thought that'd be it too, but it seems to be off by -0.5 volts on the main battery voltage, and off by at least 0.6 volts on the backup battery voltage. I might try to grab several values while powering up as many motors as I can, so I can grab a high voltage number and a low voltage number and hope they used a linear scale, but that'll most likely have to wait till SBPLI, which is just under two weeks away.
AIM --> Woloi
Unread 07-03-2004, 14:10
The formula for previous years was Vin = ((4.7/14.7)* Battery voltage)-0.4
Unread 07-03-2004, 16:50
College? What?
Yeah, that gives me voltages about 5 times too high.
Err.
Heh, I think that might work, if I just divide that by 5. A moment of clarity .
I'll try that in a little bit, hopefully it works.
AIM --> Woloi
Why MUST the 7.2v battery be attached to operate servos on the RC? Mike Rush Control System 17 06-02-2004 18:57
Quick release battery connector and 120 amps n[ate]vw Electrical 6 18-01-2003 23:41
Off-topic battery stuff. FotoPlasma Electrical 4 06-01-2003 12:19
Voltage Range of Analog Inputs Ulibrium Electrical 21 15-02-2002 14:11
connecting to the battery ahecht Technical Discussion 1 25-01-2002 17:15
