Re: Penalty Points at Regionals?
hopefully the word will get out after this weekend - if your bot is designed to push or deliver balls into the corral, you need to make sure that side of the bot is high enough so you CANT drive it through the opening
expecting the driver to see that well over the edge of the wall is unreasonable expecting the driver to get right up to the edge of the corral opening and not nudge over the line is asking too much the dimensions of the corral opening are in the field description - hopefull this will not be an issue after these 1st round of games. |
Everything that has been said above is true.
We competed at Portland (PNW) and Andy Baker led a fine team of refs. Though I did not watch every match, it seemed like 1 in 10 (matches) had a penalty. It also seemed that those matches which had one flag, normally had multiple flags. |
| Fantasy Football! | EddieMcD | Chit-Chat | 176 | 30-12-2003 18:30 |
| Hey FIRST - We're going to need a lot more regionals! | Raul | Regional Competitions | 41 | 08-11-2003 18:10 |
| Chamionship Qualification - feedback needed ASAP! | dlavery | General Forum | 97 | 11-10-2003 07:17 |
| VCU and KSC regionals | Manoel | Regional Competitions | 0 | 25-09-2001 13:44 |
