Go to Post Most of us are pretty friendly. - StephLee [more]
Unread 03-03-2002, 23:45
XRaVeNX's Avatar
XRaVeNX XRaVeNX is offline
#0610 (Crescent Robotics)
XRaVeNX is an unknown quantity at this point
Send a message via ICQ to XRaVeNX
Onboard Camera?
Last year, we had a camera mounted on our robot. The camera was wireless and would send live video to a recieving station. The station can then record the video and it was all nice and cool.
This year, I wish to do that again. Problem is that we can't use the same camera because it uses 900mhz.... and we are not allowed to use anything on 900mhz cuz it messes up the controls.
I've looked into buying a new wireless camera but the problem is that most that are above 900mhz frequency are very expensive. We are also running a little low on funds....
So I'm wondering if anyone has any ideas on how to get a camera on the robot.
I can think of 2 solutions:
1) Buy a new camera or change the existing camera to use a different frequency... mind you that would be VERY hard....
2) Mount a camera on the robot that records. It doesn't send anything. Problem is that it most likely would be a camcorder. And if I did that, there is a possibility that it would be smashed to pieces during the competition.....
So... any suggestions would be appreciated...
Thanks in advance!
XRaVeNX
Crescent FIRST Robotics - Team 610
Alex Leung - Web Page Team Leader
xravenx@rocketmail.com
http://www.crescentschool.org/robotics
Unread 04-03-2002, 01:16
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
Re: Onboard Camera?
Wouldn't the other camera run the same risk of being smashed to bits?
Anyways, I doubt that you will have much luck in changing the freq that the camera transmits at, and it prolly violates FCC rules to do so.
Wish we had spare weight....
Viva Olancho!
Unread 04-03-2002, 07:04
RebAl's Avatar
RebAl RebAl is offline
ISee It When I Believe It
None #0329 (The R.A.I.D.)
RebAl will become famous soon enough
Send a message via ICQ to RebAl Send a message via AIM to RebAl
can you buy a diffrent transmitter like 2.4 ghz
Unread 04-03-2002, 11:41
Greg McCoy's Avatar
Greg McCoy Greg McCoy is offline
boiler up!
FRC #3940 (CyberTooth)
Greg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond repute
Send a message via AIM to Greg McCoy
If you have any knowledgeable Amateur Radio operators on your team, it is possible to use Amateur TV to do it. I'm not sure what frequencies are allocated for ATV, but I know that you can do it on 6 Meters (50 MHz) and 70 cm (420 Mhz). If you use a 420 MHz system, you can use a cable ready TV with a antenna to view it without any additional gear on the receiving side, because some of the high cable channels use those frequenices. Depending on if you want color or black and white, you can probably set up a B & W system for about $100. The American Radio Relay League has more information on this. (www.arrl.org)
Remember though, an FCC licensed ham must be present during the operation of the transmitter. Identificaton rules still apply also (you must identify your call sign every 10 minutes on the air). I would but a small card with the call sign in the view of the camera on the robot. Good Luck...
Unread 04-03-2002, 14:57
D.J. Fluck
Posts: n/a
X-10
Im sure you have all seen the pop-up for the x-10 wireless camera...has anyone tried that??
Unread 04-03-2002, 19:10
FRC Key Volunteer Trainer
AKA: CrazyNate
Re: X-10
I actually know someone who has one of these, and it's my understanding that they run in the 900Mhz band, so as far as a robo-cam goes, they're out...
Nate Smith
nsmith@smythsoft.com
Unread 04-03-2002, 21:08
Greg McCoy's Avatar
boiler up!
I thought so too, but on their website it says that the XCam2 operates in the 2.4 GHz range. They are advertising 100' range, but I've used them before and reception can be kinda bad. It also appears that they are priced around $70-$120, so you better not have very many other add-on electrionics or you will be over the limit.
If you decide to use an XCam, you will have to either make it part of the "custom circuit" and run it off of a 20 Amp breaker, or off of one of their battery packs. If you run it off of the robot's main power supply it shouldn't be very hard to make a small voltage regulator to get the six volts you need to run it. Good Luck...
Unread 04-03-2002, 21:12
Wetzel's Avatar
DC Robotics
Originally posted by Greg McCoy
.... It also appears that they are priced around $70-$120, so you better not have very many other add-on electrionics or you will be over the limit.
Doesn't non-functional decorations not count towards the limit on the custom box?
Viva Olancho!
Unread 04-03-2002, 22:10
AKA: CrazyNate
Originally posted by Wetzel
Don't non-functional decorations not count towards the limit on the custom box?
Definitely...any sort of camera would be deemed non-functional, as they've ruled that you can't have a monitor showing what the camera sees in the driver station, therefore it would not count against any material or cost limitations...however, it would still have to fit within weight...
Nate Smith
Unread 05-03-2002, 00:13
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
We have one of the X-10 cameras, and they work well for this type of application. They transmit in the 2.4GHz range, and do not cause problems with the competition frequencies. You can find them for under $90. The basic package includes the camera, transmitter, receiver, NTSC interface to connect to your TV, and power supplies (the camera and transmitter run off 12v dc, so it is very easy to tap power from your robot's power system).
We used the camera quite a bit during post-season on our robot last year. It is a lot of fun to drive the robot around using only "robo-vision" when the robot is beyond your direct line of sight. I had our robot cruising around the neighborhood on July 4, and was able to get a good signal up to 300 feet away (I increased the size of the receiver antenna). It was quite a sight as the robot drove down the street with lights flashing as fireworks went off overhead, while the drivers hid around the corner in my garage!
-dave
Unread 05-03-2002, 00:29
XRaVeNX's Avatar
sweet... thanks guys...
nice... those x10 cameras have 2.4 ghz frequencies? never knew that...
so... guessing it is 90 bucks US.... so what is that Canadian? 150?
that's pretty steep... considering we are completely dry of money...
XRaVeNX
Unread 05-03-2002, 14:37
Greg McCoy's Avatar
boiler up!
Oops, sorry for the inaccurate info
Unread 05-03-2002, 14:45
RebAl's Avatar
x10 2.4 ghz camera here
It is $ 80 and comes with a free remote pan thingie, 2 days left.
Unread 05-03-2002, 16:55
Wetzel's Avatar
DC Robotics
Does that mean we get to see a new add in two days?
Viva Olancho!
Unread 05-03-2002, 20:57
Greg McCoy's Avatar
boiler up!
Haha, really. They seem to be obsessed with pop-up ads.
Q&A Discuss: wireless camera CD47-Bot Extra Discussion 3 16-01-2003 18:09
Game 2001 - spy camera archiver 2000 2 23-06-2002 23:41
digital camera archiver 1999 4 23-06-2002 23:17
stolen camera during team party at EPCOT archiver 2000 2 23-06-2002 22:51
Webcast camera angle... Joe Johnson Regional Competitions 13 11-03-2002 16:35
