Go to Post hmm..."give the gift of ChiefDelphi"? "This holiday season, send some Pontiac cheer to someone you love"? "Don't forget to put The Chief under your tree!" The possibilities are endless. - Jessica Boucher [more]
Unread 07-03-2004, 14:04
Scooter's Avatar
Scooter Scooter is offline
Galactic Doughnut!!
#0418 (Purple Haze)
Scooter will become famous soon enoughScooter will become famous soon enough
Send a message via AIM to Scooter
Re: Wireless network at compitition.
Last I heard, It was legal as long as it was open to everyone and all of the info transmitted on it was avalible (give no one an advantage).
-Bill
"Those who think that they know everything are especially annoying to those of us who do."
Unread 07-03-2004, 16:48
Mark Hamilton's Avatar
Mark Hamilton Mark Hamilton is offline
Belphegor made me do it.
#0108 (SigmaC@t)
Mark Hamilton will become famous soon enough
Send a message via ICQ to Mark Hamilton Send a message via AIM to Mark Hamilton
As part of SOAP, we set up wireless access at multiple competitions. Clear it with FIRST and the site and you should be ok.
Retired member of Team 108
Unread 07-03-2004, 19:05
gl75 gl75 is offline
AKA: Greg
#0075 (RoboRaiders)
gl75 is an unknown quantity at this point
Send a message via AIM to gl75
We had a private wireless network up used for scouting software at the NJ Regional. Didn't have any problems from FIRST.
Greg Liebowitz
Team 75 - RoboRaiders
Webmaster/Programmer
www.roboraiders.com
Unread 07-03-2004, 19:48
ArJubx ArJubx is offline
ArJubx is a jewel in the roughArJubx is a jewel in the roughArJubx is a jewel in the roughArJubx is a jewel in the rough
Thanks for the info guys, I'll try and get in contact with the regional directing people at Chesapeake to get clearance.
Just an update on my progress: I've already got the db setup done, and the data input form, working on search forms, so I should be done by midweek.
Unread 08-03-2004, 00:08
Jeffrafa's Avatar
Jeffrafa Jeffrafa is offline
Robotics Addict
AKA: Jeff Lewis
FRC #1425 (Error Code)
Jeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant future
We setup an adhoc network at the Portland Northwest Regional. I think it was secure but im not quite shure. It wasn't functional though, mostly just because we have some computer nerds on our team and they did it because they could
Team 1425 Alumnus and Mentor
I am KF7JDK - What's your callsign?
Unread 08-03-2004, 08:56
This is the scouting form, where data input happens:
Top half of page:
Bottom half of page:
Unread 08-03-2004, 09:02
Search form by team number, the search forms are designed to present alot of information in a little space, condensed for easy viewing.
Data Input:
Top of page:
Repeating Sections, these show up for each database entry that has the inputed team number:
Unread 08-03-2004, 09:25
Nick Fury Nick Fury is offline
Nick Fury has a spectacular aura aboutNick Fury has a spectacular aura about
A bit of information on security and wireless networks. It doesn't exist. 802.11b/a/g are all really crappy for security. If you plan on using a WEP key then it is found out very easily using a program like AirSnort or even Ethereal with a plugin or two. I like the idea of setting up a wireless lan at regionals though. Wireless is extremely fun to play around with and I hope that someone will be kind enought to set one up at the SC regional. Anyway, just some info. on wireless network security. Also, if you find that a network is insecure then tell the admin of the network or fix the problem yourself and then tell the admin. Don't just leave it vulnerable.
Unread 08-03-2004, 09:31
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
We used 802.11b on a 15" PB for our scouting. We did a test run at VCU and found it to work very well. We used FileMaker Pro and had it broadcasted. In Atlanta we hope to have it up so we can get iBooks to enter the info in. We didn't make the forms pretty, but they worked for me. We will probably block competers from out network by only allowing our iBooks to access the network, just for security reasons. We don't want someone to hack in and change team data. But if someone wants to see our database, I can show it to them.
Unread 08-03-2004, 11:11
What is a 15" PB?
Why would I really care about the security of our network? Like I said, I plan to let anyone setup and use the databse. Sure some might try to screw with data (Gracious Professionalism hopefully will keep these to minimum), I could then disable editing/deleting and only allow me to do that from our host comp if this issues arrises.
Unread 08-03-2004, 11:54
Joe Matt's Avatar
15" PB= 15 inch PowerBook G4
Unread 11-03-2004, 13:18
Well I had even more issues when I just tried to plop the access database onto to the webserver....how do I set a connectionstring to a web address?
Unread 11-03-2004, 13:22
AKA: Greg
#0075 (RoboRaiders)
You would need to make a DSN in your ODBC control panel. Otherwise you could do it DSN-less in ASP with the following VB code:
Dim Conn, path
path = "c:\inetpub\wwwroot\scouting.mdb"
Set Conn = Server.CreateObject("ADODB.Connection")
Conn.Open "PROVIDER=MICROSOFT.JET.OLEDB.4.0;DATA SOURCE=" & path
Greg Liebowitz
www.roboraiders.com
Unread 08-03-2004, 16:26
swando swando is offline
#0217 (ThunderChickens)
swando is on a distinguished road
Send a message via AIM to swando
team 217 has used a wireless scouting network for the past 3 years, only ever having issues with SOAP at the midwest regional (issues with control of the airwaves between teams...)
cluck.
Unread 08-03-2004, 15:25
AKA: Greg
#0075 (RoboRaiders)
Wow. Looking really good. I noticed the pages are running locally. Are you going to transfer it to a server, or just run individual clients on laptops?
Here are some screenshots from Team RoboRaider's scouting application (WebObjects):
Then of course, the deployment...
Greg Liebowitz
www.roboraiders.com
Wireless network at GLR? TravisCarpenter Regional Competitions 1 03-03-2004 01:18
Q&A Discuss: wireless camera CD47-Bot Extra Discussion 3 16-01-2003 18:09
wireless internet at competitions? Jeremy_Mc General Forum 0 14-01-2003 14:37
wireless camera Stephen P General Forum 1 11-01-2003 13:58
Did you use the 802.11b wireless LAN at EPC@T? soap108 Championship Event 21 04-01-2003 11:03
