Go to Post The game is leaking? That can only mean... - GeeTwo [more]
Unread 07-03-2004, 17:29
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: Fixing the Winch on the field
Unread 07-03-2004, 17:30
Jessica Boucher Jessica Boucher is offline
FIRST Historian
Jessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond repute
Re: pic: Fixing the Winch on the field
Kyle,
I'm assuming by your team number that you were at BAE. can you give some backstory into what happened?
jessicaboucher.com
FRC Alum, Mentor, Volunteer, lots of things.
Championship Volunteer of the Year, 2016
Advisor, NE FIRST
Unread 07-03-2004, 17:37
Paradox1350's Avatar
Paradox1350 Paradox1350 is offline
FORMER Captain now Jealous Onlooker
None #1350 (Rambot)
Paradox1350 is on a distinguished road
I could give a little. I'm not sure EXACTLY what happened, but I do know that the system for raising and lowering the bar broke. The refs were looking at it for awhile and couldn't fix it. Dean Camen and (at least it looks like it in this picture) Woodie Flowers had to go out to take a look at it in order to repair it.
New Hampshire BAE Regional Rookie All Star Award Winner 2004
Rich Wong Rich Wong is offline
NYC FIRST Planning Committee Member
no team (NYC FIRST)
Rich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond repute
Send a message via AIM to Rich Wong
Originally Posted by Jessica Boucher
Kyle,
Kyle is probably referring to the winch underneath the 12" platform use for lowering the hanging bar. Its probably stuck.
If proper weight is not applied to bar, it may not lower correctly.
popularis de ob instinctus agnitionis scientia technologia
Home website: www.nycnjfirst.org
Member of NEMO & e^(i*pi)+1 Fraternity.
Member of Friends of Robots
Member of NYCFIRST Planning Committee
Unread 07-03-2004, 18:10
OneAngryDaisy OneAngryDaisy is offline
not on CD enough...
OneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of light
I never saw this winch being used at the NJ regional- the players were manually lifting their robot off the bar.. it got sketchy when two Moe drivers lifted their robot almost 8 feet up until someone finally poked at it with a pole..
is that uneveness the reason why people at NJ never used the winch?
Unread 07-03-2004, 18:21
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
In NJ we never used the bar lowering device due to teams not wanting to and sayibng tey could just lift it off. After the MOE incident you mentioned we did tell them that if they are in the same instance again we will lower it due to time constraints. But the field staff were having some fun raising and lowering some people at times but then again this is FIRST isnt it!
-Michael Dessingue
Unread 07-03-2004, 18:54
Aaron Lussier's Avatar
Aaron Lussier Aaron Lussier is offline
Volunteer for hire
Aaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to behold
What happened at BAE was:
After the bar had been lowered to get the robots off of the bar, then because there was no weight on the bar as it was going back up, the winch cable loosened up and wrapped around the axle on the winch drum, casueing everything to lock up.
They had to lift off the platform in order to reach the winch drum, from then on we used hooks and hung on the bar from both sides on the way up and the way down so there was always even pressure on the bar.
-Aaron
Team 151 Student/Mentor 2001-2004
US Navy 2005 -2009
Volunteer 2010 - ???
Field Reset Extraordinaire
Unread 07-03-2004, 19:45
Kyle Fenton Kyle Fenton is offline
GET IT ON!!
FRC #0121 (Rhode Warrior)
Kyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud of
Send a message via AIM to Kyle Fenton
-Aaron
Yes that was basically how it happened.
However it happened twice.
I don't know why it came off the second time, but that was the match where there was 4 robots on the bar, so maybe it caused it to be uneven or something. The second time Dean Kamen himself fixed it.
Rhode Warriors
NAVSEA/Raytheon/URI/Middletown, Portsmouth, Tiverton, Mt. Hope HS
Quality Robots Since 1996
Unread 07-03-2004, 20:21
The Lucas's Avatar
CaMOElot, it is a silly place
Lifting the robot off the bar on Friday and Saturday did take quite a while. Atleast it demonstrated how difficult it is to de-hang us. The more you lift the bot the tighter the pneumatic cyclinders grip the bar. If you want to knock GizMOE off the bar, you better bring 5 guys and a stick.
Robot Inspector
Unread 07-03-2004, 21:04
jamapor jamapor is offline
AKA: Jake
#0190 (Gompei and the Herd)
Team Role: Human Player
jamapor is on a distinguished road
Send a message via AIM to jamapor
Our robot is also very difficult to remove from the bar when all devices are not working. We have two locking devices that are designed to be released under the power of servo motors. Unfortunely, during the NH regional, the servos didn't work, and we couldn't remove the locking devices. We had a backup system of strings that could manually release the locking devices, but we also ran into trouble with this. The referees ended up lowering the bar to almost chest level, and we still had trouble removing our robot. However, we then fixed the problem shortly after that match and didn't have any problems with it throughout the day. How long did it take to remove the robot off the bar the time the servos weren't working? What would you say if i said that it took upwards of 5 minutes.....
Team 190: 13 Years of Magic Smoke. And Life.
F.I.R.S.T. Veteran Team
National Quarter-Finalist (Curie) w/ 11 + 279
Arizona Regional Semi-Finalist w/ 980 + 1011
B.A.E. Regional Semi-Finalist w/ 131 + 134
pic: Wildstang Playing Field CD47-Bot Extra Discussion 20 02-03-2004 11:38
pic: Gumball Mini Field CD47-Bot Extra Discussion 14 11-02-2004 00:26
pic: Team 179 Playing Field CD47-Bot Extra Discussion 4 08-02-2004 22:28
pic: Field Reset CD47-Bot Extra Discussion 13 12-03-2003 23:56
