Re: Wireless network at compitition.
Just an update on my progress: I've already got the db setup done, and the data input form, working on search forms, so I should be done by midweek. |
We setup an adhoc network at the Portland Northwest Regional. I think it was secure but im not quite shure. It wasn't functional though, mostly just because we have some computer nerds on our team and they did it because they could
This is the scouting form, where data input happens:
Top half of page: ![]() Bottom half of page: ![]() |
Search form by team number, the search forms are designed to present alot of information in a little space, condensed for easy viewing.
Data Input: ![]() Top of page: ![]() Repeating Sections, these show up for each database entry that has the inputed team number: ![]() |
A bit of information on security and wireless networks. It doesn't exist. 802.11b/a/g are all really crappy for security. If you plan on using a WEP key then it is found out very easily using a program like AirSnort or even Ethereal with a plugin or two. I like the idea of setting up a wireless lan at regionals though. Wireless is extremely fun to play around with and I hope that someone will be kind enought to set one up at the SC regional. Anyway, just some info. on wireless network security. Also, if you find that a network is insecure then tell the admin of the network or fix the problem yourself and then tell the admin. Don't just leave it vulnerable.
We used 802.11b on a 15" PB for our scouting. We did a test run at VCU and found it to work very well. We used FileMaker Pro and had it broadcasted. In Atlanta we hope to have it up so we can get iBooks to enter the info in. We didn't make the forms pretty, but they worked for me. We will probably block competers from out network by only allowing our iBooks to access the network, just for security reasons. We don't want someone to hack in and change team data. But if someone wants to see our database, I can show it to them.
#7
What is a 15" PB?
Why would I really care about the security of our network? Like I said, I plan to let anyone setup and use the databse. Sure some might try to screw with data (Gracious Professionalism hopefully will keep these to minimum), I could then disable editing/deleting and only allow me to do that from our host comp if this issues arrises. Last edited by ArJubx : 08-03-2004 at 11:18. |
#8
15" PB= 15 inch PowerBook G4
#9
Well I had even more issues when I just tried to plop the access database onto to the webserver....how do I set a connectionstring to a web address?
#10
You would need to make a DSN in your ODBC control panel. Otherwise you could do it DSN-less in ASP with the following VB code:
Dim Conn, path path = "c:\inetpub\wwwroot\scouting.mdb" Set Conn = Server.CreateObject("ADODB.Connection") Conn.Open "PROVIDER=MICROSOFT.JET.OLEDB.4.0;DATA SOURCE=" & path |
#11
Here's an idea too...not sure if you'll like it or not, but if you could get a database onto a palm pilot for people that have 'em (and a lot of people in first have 'em) then they could do a bit of scouting and sync in with the comp you've got hooked up to the internet. Just an idea.
#12
So anyone wanna lend a helping hand...I have spent all night looking at refs for the DNS-less things, and still haven't figured it out. So I'm gonna upload my files here...hope someone can help out. Download Here |
#13
I have the whole thing setup now...working for real this time...I didn't trick myself.
![]() Tommorrow I'm going to take it to school for a more comprehensive test with more computers over a longer range. I even bought one of those range extending attennas. So for those of you who will be at the chesapeake regional. If you are interested in participating in this scouting network, just come to our pit(#1463) and get the info. We probably will have flyers to pass out to let people how to connect and use it. Quite simple actually. Join the wireless network called "FIRST" (subject to change if it clashes with the actual event one, assuming they have one, the alternate will be "FIRSTscouting". We are still trying to get official consent from the chesapeake people, it shouldn't be a problem...thru email contact they seem to think we want internet access, but now they want to see our equipment, but whatever, it shouldn't be a problem.). Then just open up your broswer and go to www.FIRSTlook.net and follow any instructions there. |
#14
team 217 has used a wireless scouting network for the past 3 years, only ever having issues with SOAP at the midwest regional (issues with control of the airwaves between teams...)
#15
Wow. Looking really good. I noticed the pages are running locally. Are you going to transfer it to a server, or just run individual clients on laptops?
Here are some screenshots from Team RoboRaider's scouting application (WebObjects): Then of course, the deployment... ![]() |
| Wireless network at GLR? | TravisCarpenter | Regional Competitions | 1 | 03-03-2004 01:18 |
| Q&A Discuss: wireless camera | CD47-Bot | Extra Discussion | 3 | 16-01-2003 18:09 |
| wireless internet at competitions? | Jeremy_Mc | General Forum | 0 | 14-01-2003 14:37 |
| wireless camera | Stephen P | General Forum | 1 | 11-01-2003 13:58 |
| Did you use the 802.11b wireless LAN at EPC@T? | soap108 | Championship Event | 21 | 04-01-2003 11:03 |
