Go to Post Cant get hair and nails done and still run a robot. - wendymom [more]
Unread 04-03-2004, 10:41
Phil_Lutz's Avatar
Phil_Lutz Phil_Lutz is offline
Phil Lutz
#0851 (Froggers)
Phil_Lutz is on a distinguished road
Send a message via Yahoo to Phil_Lutz
Re: Globe motor backdrive!!
We are using a bolt attached thru the winch drum.
This bolt is stopped by a metal bar which is actuated by a servo and tensioned by a spring.
Here we go.
Before applying power (speed) to our winch motor, programmatically we move a servo which moves the steel bar out of the way of the bolt. The steel bar is tensioned with a spring. When the speed is set to neutral the servo returns to it's start position and the bar blocks the bolt in the winch drum.
If we are still winching when the game is done, the spring tension pulls the bar back against the winch drum effectively doing the same thing.
Now for getting down.
We send the command (toggle switch) to the robot to winch down.
Motor actually winches up for 5 loops or about a 10th of a second rotating the winch drum bolt away from the bar ( .1 seconds is the time required by the servo to rotate from one extreme to the other). Servo pulls the bar out of the way and then we set the winch speed to unwind. It works extremely well.
Phil
Unread 04-03-2004, 13:44
Steve Horton Steve Horton is offline
#1180 (Atomsmashers)
Steve Horton is an unknown quantity at this point
Originally Posted by Srkasner
Our team is using a globe motor to use the mast system on our robot to pull the robot off the ground after attaching to the bar. It has enough torque to pull up but it back drives awfully! Has anyone come up with a way to stop the globe motors from back driving? Thanx!
~Steve
Team 1124
Yep ! Sailboats use "stop blocks" or cleats which allow line to pass through one way, but not the other unless unlocked. Very simple.
Unread 06-03-2004, 11:33
Phil_Lutz's Avatar
Phil Lutz
#0851 (Froggers)
Cleats. What a great idea!
Unread 08-03-2004, 00:05
EStokely's Avatar
EStokely EStokely is offline
AKA: Eric Stokely
FRC #0360 (Revolution)
EStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond repute
<<Cleats. What a great idea!>>
We used one for our F-P powered lift. Th ecleat only failed when the rope was shreaded to the inner nylon by a faulty eyehook.
Very light weight too!
Eric Stokely
Team 360 The Revolution, past mentor of 258 The Sea Dawgs
Experience is what you get when you don't get what you want.
Unread 08-03-2004, 00:10
EStokely's Avatar
AKA: Eric Stokely
Originally Posted by FadyS.
The arm is used to hang the bot and to pick up the 2X ball.
EDIT: Hanging isn't the problem because we set stops at that point when the arms are pointing all the way up. It's picking up the 2X ball that we're having trouble with.
We had the same problem with the Van Door motor. I knew it would be a problem. We used gas springs. (those things that keep the hatch up in a SUV or station wagon)
Point the arm at its max angle (in our case its straight up) and use that as the slack point (no pressure on the gas spring) attach one point on the arm itself and the other end on the arm support. As the arm lowers it compresses the gas spring (i.e. spring puts a force upward) if you balance it out correctly the arm should sit where ever its positioned and only move because the motor puts power on it.
Hope taht helps
Eric Stokely
Globe motor dimension drawing jskene Motors 0 15-02-2004 13:34
Globe Motor archiver 2000 4 24-06-2002 00:15
Globe Motor archiver 2000 0 24-06-2002 00:15
So you want to stall a Globe Motor... archiver 2000 1 24-06-2002 00:09
Globe Motors & other FIRST Suppliers at Design Show archiver 1999 2 23-06-2002 22:07
