Go to Post "You are the lead programmer now, therefore everything that goes wrong is your fault. When anything good happens its the teams fault." "But what if the robot spontaneously combusts?" "Your Fault." ~Borna - CodeTBone [more]
Unread 06-03-2004, 19:17
Greg's Avatar
Greg Greg is offline
FRC #1075 (Sinclair Sprockets)
Greg is on a distinguished road
Send a message via ICQ to Greg Send a message via MSN to Greg
Printf Question
This is probably a dumb question but I dont have as much experience with C as I'd like to Is it possible to printf a char as an ASCII character? printf_lib.c says %c is unsupported. But somehow strings enclosed in quotation marks print with no problems. How do I convert a byte to a single-character string?
Unread 06-03-2004, 19:23
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
Re: Printf Question
try creating a 1-element char array, and then assigning the value of the byte to the first element (element 0) in the array.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 06-03-2004, 20:12
Greg's Avatar
Re: Printf Question
Unfortuately, this does not seem to work. I get some garbage as output and then the RC locks up. Could you post some example code?
And, actually, this is not really critical Its ok if I dont get it working.
Unread 06-03-2004, 22:10
Computer Guy
AKA: Dav
Re: Printf Question
last i looked, there were functions to output individual bytes and other things to the output window... try the PrintString() function defined in ifi_utilities.h/c
Unread 06-03-2004, 22:59
Daniel Daniel is offline
Daniel Katanski
#0240
Daniel is on a distinguished road
Re: Printf Question
If you read the file "printf_lib.c" (I think) you will see a comment that says "%c" is not supported. The best you are going to do is put the character into a char array two long setting your character in location 0 and '\0' (or zer0) in location 1, then print it using "%s" as the format and using the array name.
char t [2];
t [0] = 61; // Or what ever you character is.
t [1] = '\0' // Null character.
printf ("%s\n", t);
Unread 07-03-2004, 00:22
Computer Guy
AKA: Dav
Re: Printf Question
char t [2];
printf ("%s\n", t);
yeah, try that... forgot about the null terminator, because i'm so used to just using strcpy gotten lax.
Unread 07-03-2004, 13:43
Greg's Avatar
Re: Printf Question
I actually figured this one out on my own last night Sorry forgot to post here.
Unread 07-03-2004, 21:24
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: Printf Question
What was the fix, anyway? I like to know so that if I ever get it, I have an idea on what it might be.
Unread 08-03-2004, 01:06
Greg's Avatar
Re: Printf Question
Actually, the byte array thing worked on MS VC6.0 but didnt in MPLAB One way of sending an unsigned char as an ascii character is actually very simple. I just do what printf_lib.c does when sending a byte - assign the unsigned char to the transmit register (I think it is called TXREG) and then call WaitForTXEmpty.
Unread 08-03-2004, 06:57
Programming User
Re: Printf Question
Tricky. That interesting. Thanks for that info.
MIM's question of the day on programming. Gene F Programming 3 24-02-2004 16:32
A question about control system options computhief263 Control System 7 04-02-2004 14:46
MnM EASY Question of the Day Winners! Mike Bonham General Forum 22 03-05-2002 21:21
Chief Delphi Site Question Mike Bonham General Forum 1 16-02-2002 22:18
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
