Go to Post This is one case where I really wish Andymark didn't listen to their customers so well. - ASD20 [more]
Unread 08-03-2004, 09:11
HuskieRobotics HuskieRobotics is offline
HuskieRobotics has a little shameless behaviour in the past
Exclamation HELP ME!!!!!!!!!!!!!!!
In the tracker default code it says (at the very bottom)
// both trackers have an angular solution; calculate beacon vector
// here using the known baseline distance between the trackers and
// angles derived from the two Tracker_Data[].Position variables
// calculate new drive motor PWM values here
I would like to know what you are sopposed to put here OR is it just telling you what it is doing. but since there is no line of code to do anything below it i suspect that i have to do something i just don't know what. Please help me. Thanks!!!!!!!!!!!!!!!
Unread 08-03-2004, 10:22
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
Re: HELP ME!!!!!!!!!!!!!!!
the code in the tracker package does not actually move the robot, but instead just locks the trackers onto the target. moving the robot is up to you.
if you want code that moves the robot as well, get the navigate package.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 08-03-2004, 10:23
Exclamation Re: What do u put here???????
Where can i get that?????
Unread 08-03-2004, 11:27
jacob_dilles's Avatar
jacob_dilles jacob_dilles is offline
AKA: theshadow
FRC #0620 (WarBots)
jacob_dilles will become famous soon enough
Send a message via AIM to jacob_dilles
http://kevin.org/frc/
"You're not a real programmer until all your sentences end with semicolons;"
Gus can put the big balls on the goals on the bridge!!! archiver 2001 0 24-06-2002 01:30
robot which can put balls on top of goals on bridge archiver 2001 4 24-06-2002 00:48
Is there a size regulation for the pit area if we wanted to put up a banner Ragin_Kage General Forum 6 14-03-2002 15:33
put effort into thread subject Brandon Martus General Forum 12 28-01-2002 19:12
How can I put a picture on my post CMC CD Forum Support 1 04-06-2001 09:26
