Go to Post One of the most important resources of all: [URL="http://frc-manual.usfirst.org/"]The Manual[/URL] - lorem3k [more]
Unread 06-03-2004, 08:41
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Wat the Hook Gon Be?
I've seen a lot of cool hooks used for hanging over the last couple and it got me wondering what kind of hooks people are using this year.
If you are using a hook this year:
What kind of hook is it?
What is it made of and how heavy is it?
Did you make it or did you buy it?
How did you make it or where did you buy it?
From current competitions, which kind of hooks have you seen working best?
Does it stay attached to the arm or does it come off when you hang?
If it come unattached how did you do it? Velcro? Shear pin?
My team is using a pirate like single pronged hook made of aluminum on a band saw. It weighs less than 1/2 lb and it comes unattached with either the shear pin or velcro.
Unread 06-03-2004, 10:08
Marygrace's Avatar
Marygrace Marygrace is offline
School=Build Season YAY
AKA: Mary
#0294 (Beach Cities Robotics)
Team Role: Student
Marygrace is just really niceMarygrace is just really niceMarygrace is just really niceMarygrace is just really niceMarygrace is just really nice
Send a message via AIM to Marygrace Send a message via Yahoo to Marygrace
Re: Wat the Hook Gon Be?
we have a grapling hook made out of aluminum. It was waterjetted by one of our big sponsors American Aircraft. It comes unattached by Velcro. The actual part of the arm is like folded in with our multiplier ball grabber then when we are ready, (it is srping loaded) the second portion of the arm swings out, we position the hook, pull away, and then let the winch do the rest.
Unread 06-03-2004, 11:31
Roland's Avatar
Roland Roland is offline
Post-A-Holic
#1466
Team Role: Webmaster
Roland is infamous around these partsRoland is infamous around these partsRoland is infamous around these parts
Our hook is made out of carbon fiber. It slips onto the end of a long piece of fiberglass that we retract once the hook is on the bar. It's then connected to the robot by a long piece of Spectra. There's a little catch on the hook that holds it on to the bar. Oh, and we cut it on a band saw.
Unread 06-03-2004, 11:37
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
nothing fancy, a simple caribeaner attached to the bot w/ steel cable....KISS
Unread 07-03-2004, 10:12
Dick Linn's Avatar
no team (Synergy)
Originally Posted by Roland
Our hook is made out of carbon fiber. ...
Is carbon fiber allowed this year? Best check.
Our hook was just a piece of 1/4 x 5/8 steel bent with a hammer. It was mounted somewhat oddly - sort of horizontally with the hook part down. It would rub the bar and flip up into position. The cable and tube spring tension was all that held it in place. Crude but effective. We got all 4 robots on the bar in one match.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 07-03-2004, 10:46
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
Carbon Fiber is allowed this year since there's no ban on exotic materials like previous years. As long as you can account for it in your $3500 limit you can us it.
Our hook is more than just a hook. For those of you who were at the New Jersey regional you know what I'm talking about. It is aluminum tube (1"x1") cut and tig welded together with four 90 degree bends (two per side) that actually make two points to hook on to. Inside these hooks are two rollers, one on each side, connected by a timing belt to each other. This belt and the pulleys ride on the bar. Connected to one of the pulleys is a sprocket and a chain going to another sprocket and a motor on top of the hook. Once the arm is extended with two pneumatic cylinders the hook reaches over the bar and the cylinders are then retracted pulling us up. Now here's the fun part, when another robot goes for the bar, we just activate the motor and our robot still hooked and hanging can move sideways back and forth across the bar to block the opponents chance of hanging. There's a photo of our hook in the "Pics from NJ", the first column second photo down. www.pbase.com/sscamatt/robot...ew jersey day 1
[EDIT] I'm having problems getting the link to work. "jersey day 1" is also part of the link but I can't get it included. If you go to the "General Forum" then to "Pics from NJ" click the link in the first post our robot hook is shown in the first column second pic down. And if anyone knows how to make the link work please let me know.[EDIT]
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 07-03-2004, 16:09
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
We definately had the most obvious hook, a CANE! See http://1418.org
(Incedentally, we were complemented on it when we won rookie all-star)
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 08-03-2004, 11:59
http://www.pbase.com/sscamatt/robot....rsey%20day%201
you can insert "%20" in place of any blanks.
I visited J&J on Saturday and saw your rolling hook in action. It was very impressive. One match you kept an opponent from scoring by making them place their hook on top of yours. Not supported by the bar= no score.
Unread 08-03-2004, 12:07
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Here is our hook. It is made out of 1/2 aluminum round stock. IT is just like a body clip.
The diameter of the opening in the hook is smaller than that of the bar therefore it snaps back around the bar attaching us to the bar.
(the only way to get us of the bar is upwards....)
here is the link:
http://www.tahsroboticsteam.org/Pict...n/100_0712.JPG
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 08-03-2004, 12:25
Alavinus's Avatar
Alavinus Alavinus is offline
Siege Weapon/Robotics Guy
AKA: Andrew LaVinus
Alavinus will become famous soon enoughAlavinus will become famous soon enough
Send a message via AIM to Alavinus
Since we had the weight luxury, we went ahead and made our hooks from 1/4 inch thick 1 & 1/4 wide steel barstock. The hooks probably weigh in, at most, about a pound a piece and have 1/8 thick sheet latex glued on to improve grip. They are mounted at the mid-section of our plow/ball grabber with two or three 1/4-20 bolts
We made it by cutting the steel with a reciprocating saw, cold forging it with a hammer, and then radiused it around a pipe. (Yes it was hard to do)
Unread 08-03-2004, 16:34
Elgin Clock's Avatar
Here is a direct link to the picture of our robot with the hook/Shimmy on the left.
http://www.pbase.com/image/26627878
And look, in the background!! Itsa ME!! Before I shaved my beard, and still with hair (which may change by next week cause of a bet I made with the team...)
Edit: A link would be nice to include! :-D
Edit 2: A working link, that is...
Unread 08-03-2004, 17:44
tenfour's Avatar
tenfour tenfour is offline
AKA: Chris
#0696 (The Circuit Breakers)
tenfour will become famous soon enough
Send a message via AIM to tenfour
We made ours outta steel 3/8" bar stock. We then bent it on the 'ol brake. Looks like it was made by Jesse James himself. It is kinda the shape of the top of a pimp cane.
-2004 Arizona Regional Finalists (thanks 80 and 498)
-2004 Arizona Regional Sportsmanship Award
-2003 Los Angeles, CA Regional Finalists
-2003 Phoenix, AZ Regional Semifinalists
-2003 Phoenix, AZ Regional 3rd Seed.
-2002 Los Angeles, CA Regional Semi-Finalists
-2001 Los Angeles, CA Regional Semi-Finalists
FIRST Mantra - When Lawyer-ism fails, Gracious Professionalism Prevails.
(Yes, it is "BCR Orange")
Unread 08-03-2004, 18:30
jacob_dilles's Avatar
jacob_dilles jacob_dilles is offline
AKA: theshadow
FRC #0620 (WarBots)
jacob_dilles will become famous soon enough
Send a message via AIM to jacob_dilles
our 2 hooks ( 6" apart ) are 1/8" alluminum plate. they were originaly 2 1/4" plates, but we reduced it to save weight. we cut them on the band saw i cant believe it actualy holds the weight of the robot, but it does....
"You're not a real programmer until all your sentences end with semicolons;"
Unread 08-03-2004, 18:47
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Ours is some sort of wall mounted hook made from tubular steel we bought from home depot. It surely weighs under a 6 ounces or so, and it has not come close to thinking about failing yet. It sits in a little holder and comes off when we hang and is attached with 3/16 steel cable (total weight, around 4 ounces.) I think that is KISS.
Team 1257
Unread 08-03-2004, 18:54
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
We have hooks made out of 3/8" polycarbonate. Here's a picture.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Whos gonna be in Double Tree in Houstin BoticsPUNK Championship Event 9 08-04-2003 03:48
I'm gonna have to start hangin out with you guys/gals archiver 2001 4 23-06-2002 23:39
What's gonna happen to the seniors??? archiver 1999 12 23-06-2002 22:52
tommorow is gonna be judgment day Greg Perkins Off-Season Events 0 14-06-2002 10:45
Batttery hook up piconysm Technical Discussion 3 17-01-2002 18:21
