Go to Post Just to be clear, NOTHING anyone says here is a confirmation. The ONLY source for official answers to questions like this is the FIRST Q&A system. - dlavery [more]
Unread 08-03-2004, 10:13
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
Re: Code Size
Originally Posted by KenWittlief
make sure you comment out ALL the printF statements if you want to min the amount of code used
and they are in other places - like main.c - if you have only one printf statement the compiler dumps a TON of junk into your hex file.
actually, if you truly want the smallest code possible, don't include printf_lib in the first place (this will require commenting/taking out all the printf statements anyways)
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 08-03-2004, 11:29
jacob_dilles's Avatar
jacob_dilles jacob_dilles is offline
AKA: theshadow
FRC #0620 (WarBots)
jacob_dilles will become famous soon enough
Send a message via AIM to jacob_dilles
Re: Code Size
yeah for our last revision of autonimous i did a global find for printf and took them all out, and then un-included it. it cut down on the size by 13k
"You're not a real programmer until all your sentences end with semicolons;"
Unread 08-03-2004, 14:18
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: Code Size
In addition you should also remove printf_lib.* from the project.
Unread 08-03-2004, 14:49
Computer Guy
AKA: Dav
Re: Code Size
that's what i said.
Unread 08-03-2004, 15:11
Programming User
Re: Code Size
that's what i said.
Whoops... Didn't notice that. Sorry for the double respones.
Unread 08-03-2004, 17:48
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Code Size
I modified my printf_lib.c so it only compiles if I define _debug_.
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
Interrupt timer, executing code asap? SeanCassidy Programming 10 07-03-2004 01:47
How to measure execution time? And code size? gnormhurst Programming 17 17-02-2004 08:06
Does your team use the Default code. Jeff McCune General Forum 2 09-01-2003 14:46
