Re: IR sensors: dealing with reflections?
Two things...make sure you place the sensors in a holder that blocks off the sides. My other suggestion would be to add extra fixed sensors to test against. So if your rotating sensors pick up a signal and so do your fixed side sensors and they're not the same angle then ignore it.
| Getting Fancy with Sensors | FadyS. | Programming | 30 | 10-03-2004 15:02 |
| Why not analog sensors?? | gnormhurst | Programming | 16 | 07-03-2004 16:14 |
| Interrupts and rotation sensors | kor | Programming | 3 | 12-02-2004 11:05 |
| wiring diagram for light sensors??? | pagemauck | Control System | 1 | 21-01-2004 16:32 |
| what type of sensors are good and convenient | magical hands | Programming | 7 | 04-01-2004 23:04 |
