Go to Post Expect a lot of noise, unexpected things going wrong, and most of all, tons and tons of fun. - nitneylion452 [more]
Unread 08-03-2004, 15:52
Allison Allison is offline
AKA: Allison Phelps
FRC #1024 (Kil-A-Bytes)
Allison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant future
setting autonomous mode
is it allowed to have something like a switch or jumpers on your OI to set your autonomous mode or does it have to be done on the robot? if not how do we choose the autonomous mode we want?
thanks in advance
allison
Unread 08-03-2004, 16:03
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: setting autonomous mode
thanks in advance
allison
Somebody will have to correct me if I'm wrong, but the way the code is, I believe that you read the inputs from the OI once before you enter autonomous mode. However, I'm not sure if the OI will actually send anything to the robot.
The safe way is to have switches on the robot that you set to indicate which autonomous mode you want. Your program then reads these and figures out what you want it to do from them.
Unread 08-03-2004, 16:39
We've got a rotary switch on our OI that selects from the menu of autonomous options. The OI inputs do get passed to the robot during the disabled period before autonomous mode begins, so you can read the mode selection and store it somewhere to be used during
autonomous mode. The OI won't be active while autonomous mode is underway -- default values will be transmitted to the robot -- so you'll have to make sure not to accidentally try to read the mode selection after the match begins.
Unread 08-03-2004, 17:50
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
I read it when Default_Routine() is ran. Then I store it to a variable and use that in User_Autonomous_Code().
Unread 08-03-2004, 18:47
ultramrw21 ultramrw21 is offline
ultramrw21 is an unknown quantity at this point
We have three binary switches on the robot to select one of the 8 auto modes. Its worked well so far, but it took a while to explain it to the drivers that set the robot before a round.
Unread 08-03-2004, 18:54
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
We do the same thing. What we do is make a sheet your coach (or drivers) can look at which has the program numbers in decimel, along with the names. Then next to the decemel number indicate which swithes need to be on or off to input that decimel number.
Unread 08-03-2004, 19:42
jacob_dilles's Avatar
jacob_dilles jacob_dilles is offline
AKA: theshadow
FRC #0620 (WarBots)
jacob_dilles will become famous soon enough
Send a message via AIM to jacob_dilles
i was wondering if anyone had any sucess with reading switches off the OI after the match had started and before autonomus was enabled?
"You're not a real programmer until all your sentences end with semicolons;"
Unread 08-03-2004, 19:54
team update 13 said the OI values are read when the bot is diabled, so you should be able to send them from there
I dont think we have enough switches left free on the OI - we have 4 switches onthe bot tied to the rc_dig_inputs to tell it what to do in auton mode
the most important one you MUST have is a disable - sooner or later you are going to want to sit out auton mode.
Unread 08-03-2004, 19:58
AKA: theshadow
FRC #0620 (WarBots)
well currently were only using 2 joystics... that leaves 8 switches open, thats like 64 programs or watever. so i could have done it that way. but there are two big red togle switches on the robot that are clearly labled "disable/enable autonomus" and "knock ball/dont knock ball". it makes it pretty easy. we have 4 digital IOs on the rc left; with just 2 banner sensors. next year i hope they give us more inputs!
Unread 08-03-2004, 20:35
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
2^8 = 256
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 08-03-2004, 20:37
AKA: theshadow
FRC #0620 (WarBots)
lol shush im writing a history paper and CDing at the same time. not thinking using the right part of my brain
Initializing autonomous mode Mr. Lim Programming 7 02-02-2004 07:26
how can you use a gyro in autonomous mode magical hands Programming 3 02-01-2004 13:31
Programming Autonomous mode Jared Stofflett Programming 3 11-11-2003 09:32
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
autonomous mode timer Don Programming 6 09-02-2003 22:16
