Go to Post A robot is never "complete" - [more]
Unread 24-02-2004, 16:41
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
Simple Autonomous Mode Example
Although you cannot just drop this in without any modifications (it wouldn't really do anything of use in its current form), this code does provide a good foundation for a simple blind-reckoning (no sensor input) autonomous mode. It is expandable to have as many steps as wanted, and simple to use for timing. It doesn't use interrupts for timing, if you want to do that instead, you'll have to implement it yourself. This code is only for teams that need to get off the ground because they don't quite understand autonomous, and want a working example they can play with. Essentially, this is just a simple state machine and timer combo.
//define as many states as you want here
//each state is a "step" of the program
#define AUTO_FIRST_STATE	1
#define AUTO_SECOND_STATE	2
#define AUTO_THIRD_STATE	3
#define AUTO_FINISHED		4
//A handy-dandy macro to convert a number of seconds into a number of 26.2ms ticks
#define SECS_TO_TICKS(a)	( ((int)(a)) * 10000 / 262 )
//And milliseconds too:
#define MSECS_TO_TICKS(a)	( ((int)(a)) * 10 / 262 )
void User_Autonomous_Code(void)
	static char AUTO_STATE = AUTO_FIRST_STATE;
	static long tickCount = 0;
 	while (autonomous_mode)
   		if (statusflag.NEW_SPI_DATA)
        		Getdata(&rxdata);
			tickCount++;	//tickCount contains the number of
					//26.2ms "ticks" since the start of the current step
			switch (AUTO_STATE)
				case AUTO_FIRST_STATE:
					//for demostration purposes, make the robot go forward
					pwm01 = pwm02 = 254;
					//are we done with this step yet?
					//(in this example, the first step goes for 2 seconds)
					if(tickCount >= SECS_TO_TICKS(2))
						//make us go to the next step
						AUTO_STATE = AUTO_SECOND_STATE;
						//reset the step timer
						tickCount = 0;
					break;
				case AUTO_SECOND_STATE:
					//in this demo, the second step will be to spin
					pwm01 = 254; pwm02 = 0;
					//this time, we'll spin for 0.7 seconds = 700ms
					if(tickCount >= MSECS_TO_TICKS(700))
						AUTO_STATE = AUTO_THIRD_STATE;
						tickCount = 0;
					break;
				case AUTO_THIRD_STATE:
					//finally, we'll go forward again
					//done yet?
					//going forward for 4 seconds this time
					if(tickCount >= SECS_TO_TICKS(4))
						AUTO_STATE = AUTO_FINISHED;
						tickCount = 0;
					break;
				case AUTO_FINISHED:
					pwm01 = pwm02 = 127;
					break;
				default:
			Putdata(&txdata);
			Generate_Pwms(pwm13,pwm14,pwm15,pwm16);
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 24-02-2004, 16:45
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Simple Autonomous Mode Example
You know, I'm doing basically the same thing using simpler code. Plus, You can write REALLY LONG scripts without REALLY lengthening the code. I'll Release my source about a week or 2 after regionals.
Hint: Arrays
Unread 24-02-2004, 16:50
Computer Guy
AKA: Dav
Hint: Arrays
arrays indeed - if i myself were actually using dead reckoning, chances are I'd be using the approach I'm guessing you're hinting at. In this instance, however, I'm really just trying to make the code as straightforward as possible, so this seemed like a better idea.
Unread 08-03-2004, 20:13
Computer Guy
AKA: Dav
A NOTE TO ANYONE USING THE ABOVE CODE:
I made a slight error in the definitions of the SECS_TO_TICKS and MSECS_TO_TICKS macros. You'll need to change them to the following:
#define SECS_TO_TICKS(a)	( ((long)(a)) * 10000 / 262 )
#define MSECS_TO_TICKS(a)	( ((long)(a)) * 10 / 262 )
otherwise, the values will overflow for a value greater than about 3 seconds.
Unread 08-03-2004, 20:16
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
I'm sure rookie teams without much programming experience will find that helpful.
Unread 08-03-2004, 20:22
jacob_dilles's Avatar
jacob_dilles jacob_dilles is offline
AKA: theshadow
FRC #0620 (WarBots)
jacob_dilles will become famous soon enough
Send a message via AIM to jacob_dilles
another simple auton example is our code... basicly it goes strait. then it turns about 75degrees. then it goes foward, opens its arms, and swings and knocks off the ball. it is based on a wheel counter inturpt... so you can make it go as fast or as slow as you want.
************jacobs autonoumus code....********************
  		relay8_fwd = !rc_dig_in18;  			// Power pump only if pressure switch is on.
  		relay8_rev = 0;
//this start start it moving... ladies and gents start your engins
		if(count >= 0 && count < 2) {
 			pwm15 = 127 + 50;			//drive strait
			pwm16 = 127 + 50;			//drive strait
//turn to get the ball
	if(count> 12 && count < 14) {
		foward = 0;					//turn off correction algoritiom (cuz were turning duh)
 			pwm15 = 127 + 50;			//make right wheel turn fowards
			pwm16 = 127 - 50;			//make left wheel turn backwards
			pwm01 = 254;				//make arm go up
		if(rc_dig_in16 == 1) { 				//make sure arm doesnt go to high!!!
			pwm01 = 127;
//then we have to go strait slightly to get to the ball
		if(count > 14 && count < 16) {
 			pwm15 = 127 + 50;			//go foward
			pwm16 = 127 + 50;			//go foward
			relay3_fwd = 1;				//open the gripers...
			relay3_rev = 0;				//open the grpiers...
//now turn to AND close the gippers to knock/grab ball off... combo move HI-YAH
		if(count > 18 && count < 23) {
 			pwm15 = 127 - 50;			//turn the other way
			pwm16 = 127 + 50;			//turn the other way
			relay3_fwd = 0;				//close grippers
			relay3_rev = 1;				//close grippers
//NOW we shut down motors
	if(count > 24 && count < 100) {
 		pwm15 = 127;					//turn the other way
		pwm16 = 127;					//turn the other way
*******************end jacobs auton code******************
as for the inturpst... that is not as hard as every one is making them out to be. there is a great white paper called inturpts for dummies, i sugjest you read it if your intrested. ive never done them before and it worked very well.
"You're not a real programmer until all your sentences end with semicolons;"
Initializing autonomous mode Mr. Lim Programming 7 02-02-2004 07:26
how can you use a gyro in autonomous mode magical hands Programming 3 02-01-2004 13:31
Programming Autonomous mode Jared Stofflett Programming 3 11-11-2003 09:32
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
autonomous mode timer Don Programming 6 09-02-2003 22:16
