Go to Post [on reputation] They're just dots. - Brandon Martus [more]
Unread 07-03-2004, 15:23
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Slickest drive transmission yet...
For everyone that has attempted, or wants to attempt, to design their own gearbox/transmission design for the FIRST competitions, sit up and take notice - there is a new sheriff in town!
I had a chance to see the drive system designed and built by Team 33 this past weekend at the Richmond regional competition. It is, without a doubt, one of the most elegant designs I have seen in the nine years I have been working with the FIRST program. They have built a dual-motor, four-speed, shift-on-the-fly, AUTOMATIC transmission that is amazing.
It is the ultimate in simplicity - you can build it with a lathe and a drill press with an X-Y table. The gearbox itself is very small and compact - under two pounds. The gearbox and combination of the motors are separate subsystems, so the gearbox can be used with a single-motor (or triple-motor) design without any redesign. The shifting gears are all cut from 12, 14 and 20-tooth, 16-pitch pinion wire - the large tooth profile, small DP-to-diameter ratio, plus 15 mils of designed-in backlash makes on-the-fly shifting trivial.
But the best part is the automatic shifting function. The system detects wheel speed to determine the output of the gearbox. They have calculated the power curves for transmission in each of the four gears, and determined the optimal crossover points for the curves. The control system has been programmed to sense when the system reaches one of the crossover points, and automatically fires one or both of the shifting pistons to bump up or down one gear. All the robot driver has to do is push the throttle, and the system just goes. It auto-shifts all the way up to fourth gear for high-speed runs. Bump into something and need to start pushing harder? No problem - it just senses the drop in speed and auto-shifts back into first gear.
The Killer Bees have set up a great demo board with a prototype of the design all laid out, along with their design specs and performance analysis. They are very open with the design, and indicated that they will be writing up a white paper on it later in the year. If you are going to be at the Detroit or Canadian regionals, make sure you find a way to see this drive transmission in action (and if you end up against them in competition, you will definitely see how effective it is). My only regret is that I didn't get a chance to get any photos of their gearbox - if anyone has any, please post them!
-dave
Unread 07-03-2004, 15:44
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Re: Slickest drive transmission yet...
I spent a good amount of time just staring at that thing, it was absolutely fantastic. If anyone has a chance to, I highly reccommended checking it out. I'm new to FIRST, so I don't know how common this kind of thing is, but I was blown away.
My team took some video of it, along with their coach explaining it and it will be up on our website soon.
I wonder how they could be topped...
(A CVT perhaps? )
Unread 07-03-2004, 16:54
dlavery's Avatar
Curmudgeon
(A CVT perhaps? )
I loved the CVT designs that have popped up a few times in recent years. But with ones like the ThunderChickens design, we could only look on with envy and the realization that it was a design we could not build without a much better fabrication capability. That is why the Killer Bees design is so brilliant - they get a similar level of performance (particularly with the automatic shifting function), but you don't need any high-end tooling to put it together. Just about anyone with access to a moderate high school shop can build it. In that respect, it is a truly elegant design.
-dave
Unread 07-03-2004, 17:16
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Speaking of Drive systems.
I would like to thank Dave Lavery and the crew at Team 116 for the awesome shift on the fly gearbox they shared with the FIRST community.
We used that this year, and so far have been unstoppable to get our bot up on that platforms! (Both of them)
We modified it a tiny bit, and included a little extra spiffy design work in the end plates and the gears.
Thank you Team 116, and be sure to stop by our pits in Atlanta to see what kind of full drive system we came up with including your gear box!
Unread 07-03-2004, 17:27
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Thanks for mentioning this. I can't wait to see a whitepaper. I've started to look for a new drive system for next year and something like this sounds great. We don't have the best machining ability so something that can't be done in a high school shop would be great for every team. Since next year will be our third year it would be nice to make a transition from a single speed chain drive system to a multi-speed transmission. I will have to look into this.
Unread 07-03-2004, 18:18
FRC #0701 (RoboVikes)
actually our team(701) built a CVT transmission much like thunderchickens without that much machining capabilities UC davis did housing plates BUT it wouldn't have been hard to do it w/ out mill but when the mill came we didn't know how to use it ...lol (it came like 1 week into the competition)
Team 701
Unread 07-03-2004, 18:34
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
If I remember correctly, your system only gave you a constant torque at all speeds, rather than the Thunderchickens, which gives them variable torque at different speeds. (It's still a very cool pseudo-CVT, and does work well for it's intended purpose, congrats for pulling it off!)
To get back on topic, 33's drive system sure sounds amazing, and I can't wait to see pictures of it.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 08-03-2004, 00:48
dlavery's Avatar
Curmudgeon
Thank you very much for the kind words. Working with the team to design that transmission was a lot of fun, and we learned a lot! But after looking at Team 33's design, all pride of ownership in ours went right out the window! Our immediate reaction was "we GOTTA build one of those next year!"
-dave
Unread 08-03-2004, 08:29
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
I agree it is the ultimate in simplicity and function. Great job.
Enclosed is a picture of their demo board - I did not want to intrude for one of their actual gearbox.
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
Unread 08-03-2004, 22:03
Jim Zondag's Avatar
Jim Zondag Jim Zondag is offline
Team Leader
FRC #0033 (Killer Bees)
Jim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond repute
Thanks, I'm glad everyone likes our design.
We have made two speed transmissions for the past several years. Each year we try to make them simpler and smaller. I found that with the kind of high/low shift range that I like to have (3:1 or more) that the robot would tend to lurch severely if you downshifted at high speeds. I really want to make a 3 speed with an intermediate gear to help this. It turned out it was easier to build a 4 speed than a 3 speed ( its really two small two-speeds in series). We focused the design around reliablity and ease of construction, the demo unit on display was made entirely by high school students in a few evenings using no special tooling.
Once I had a design with 4 gears I was pretty much forced to automate the shifting in order to keep from overloading the driver. I talked with a few Automatic Transmission experts at DaimlerChrysler on how to do a shift scheduler and viola....a fully automatic electronic robot transmission.
It really is pretty neat, providing a nearly flat power output across a very wide RPM band with a 5:1 total shift span.
I plan on posting the design and engineering here as soon as I get a good set of drawings made up (I'm not a CAD guy, I made the ones in the robot from a napkin sketch).
"To learn what is possible, we must attempt the impossible." Arthur C. Clarke
Unread 08-03-2004, 22:15
This may sound wierd.......but we still haven't tested our low speed yet........haha....we will hook up the current sensors etc...AT COMPETITION!!! (funny i know) ....but they actually said their transmission doesn't give a different torque......torque remains constant....as for ours we still think it might give dif torque outputs but they say it won't..........we probably have to test it....... lol...
btw AWESOME transmission........just saw the pic
Team 701
Unread 09-03-2004, 16:27
Mike K Mike K is offline
Battery Boy
#0033 (Killer Bees)
Team Role: Student
Mike K is on a distinguished road
Send a message via AIM to Mike K
I do belive that a lot of the teams that saw the 4 speed where very impressed. By the end of the day i was tired of explaning the thing.
Unread 09-03-2004, 20:01
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Is there a picture of the real thing? That would serve us both better than me asking a bunch of questions. Thanks.
Unread 09-03-2004, 20:45
Eric Yahrmatter's Avatar
Eric Yahrmatter Eric Yahrmatter is offline
Eric Yahrmatter has a spectacular aura aboutEric Yahrmatter has a spectacular aura about
Hey, if u have any questions about our trannys or how they were built ask me because I built them!
Have fun @ all ur regionals.
-Eric Y
P.S. Killa Bees in da club!!!
Unread 09-03-2004, 21:04
Sam J. Sam J. is offline
AKA: newmatics geek
#0435 (Robodogs)
Team Role: Student
Sam J. is an unknown quantity at this point
Send a message via AIM to Sam J.
I saw the robot in competition, and it was great. I was really impressed with how you were able to speed accross the field at high speed, then push the mobile goal with little effort. I am guessing that this is a shift on-the-fly transmission. Could someone tell me how some teams have transmissions that cannot be shifted while driving, and others can? How are they diffrent? Sorry if these sound like stupid questions to you but, I do not know that much about drive systems.
Shifting Gears MBosompra Technical Discussion 71 23-07-2004 02:49
1 stick drive to 2 stick drive wayne 05 Programming 18 01-04-2004 16:41
White Paper Discuss: Dual-motor, dual-speed drive transmission design CD47-Bot Extra Discussion 9 03-09-2003 10:40
how does crab drive work? Soukup Technical Discussion 13 25-04-2003 11:31
Direct drive or Chain? Suneet Technical Discussion 32 27-03-2003 23:00
