Go to Post Don't be in a rush to build a robot until you know what robot it is you need to build. - Chris Fultz [more]
Unread 08-03-2004, 15:43
jjv jjv is offline
jjv is an unknown quantity at this point
Re: Who's Blue? Who's Red?
Who told you that? EL lighting has been used by several teams in previous years, and it has always fallen under the legal heading of "non-functional decorations" I cannot find anything in the rules that prevent it from being used this year. Team 116 is using it in their OI this year.[/quote]
I asked FIRST on the Q&A system.
Actually, i guess I asked about extra LED's, but I assumed that the response would be the same...
Q: Is it permitted to connect additional LEDs to the Team Color LED's, as long as the proper colors are used, i.e., strips of red or blue to increase team visibility?
A: No.
Unread 08-03-2004, 15:46
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Ha Ha!! TireFlys!! Classic. I remember a couple summers ago when those little doo-dads were on just about every car I drove, and a few of my friends car's as well!!
Thanks for the inside info into this situation Dave. The world is about checks and balances and time contraints, so I'm glad I was not like every one else in this thread and jump the gun and post negatively about the LED's till I found out the story behind them.
That said - The only suggestion I have for the LED's is to make them blink just a bit faster when they are on the playing field and are controlled by the system. They seem to blink slower on the playing field than when in the pits or during testing off the field while under tether.
Thanks to the folks at Innovation FIRST for coming through for us once again. That is one the reason for their award last year in Houston. They are always there for FIRST no matter how much of a deadline they may be under!
Unread 08-03-2004, 15:50
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
It may be hard for spectators to see which teams each robot belongs to... but for the drivers, I think they should know exactly who their alliance partner is and exactly what their robot looks like. You shouldn't have to look at for a light during a match to know who you're with and who you're matched against. Go scout them beforehand.
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 08-03-2004, 15:51
A: No.
I think this is of you asking a very specific question, and then generalizing the answer. I beleive the reason they said no to you is not because you can't have extra LEDs on your robot, but because you can't hook those LEDs up to the same place as the team color LEDs. See this response also:
ID: 516 Section: 5.2.10 Status: Answered Date Answered: 2/5/2004
Q: Can LEDs be classified as "nonfunctional decoration"? If so, are they exempt from the $200 limit on electronic components. Furthermore, can an entire array of LEDs all run on the same circuit breaker?
A: Yes as long as they are truly decorative and not informative.
Unread 08-03-2004, 16:30
pi_guy578 pi_guy578 is offline
Programmer/Electrician
AKA: Jake
FRC #0578 (Blue Lightning)
pi_guy578 has a spectacular aura aboutpi_guy578 has a spectacular aura about
Send a message via AIM to pi_guy578
We wanted (FIRST said no) to run red and blue EL wires up our arms and around our chassis, and connect to the LED's, so that when we were red, the red wires would light up, and vice versa. Not only would it be easier to tell, it would look cool.
Also, I don't think the LED output connectors are ment to supply more power than is required by the LEDs. i.e. run it off the circuit breaker instead of taking power from the RC...
Unread 08-03-2004, 16:59
WebWader125
Posts: n/a
Thanks for the info on the LED's, and thanks to Innovation First for coming through! I didn't mean to be negative; I was just interested in people's thoughts on how well they worked. I think it's hard to beat the old strobes for visibility. I agree that if they blinked faster they'd be easier to see.
Unread 08-03-2004, 22:10
jjv jjv is offline
true, but it would still need to be connected to the leds to determine which color... yes, i know we could put a color sensor in to determine that, but it wasn't a priority...
Unread 08-03-2004, 22:24
Guest
Posts: n/a
My team asked this question and we basically built a panel of LEDs ourselves. We didn't connect the LED panels to the team leds but had them controlled by the software.
Unforunately, we never had time to connect the LEDs to the robot
VCU Finals Scores soap108 Regional Competitions 0 06-03-2004 15:19
Mars Rover on Red vs. Blue PSA#6 JVN NASA Discussion 14 09-02-2004 00:50
Mars Rovers on Red vs. Blue Kevin Kolodziej Chit-Chat 1 06-02-2004 06:27
Can you use PWMs (Red or Blue) with the edubot controller? Dr.Bot Robotics Education and Curriculum 3 04-12-2003 23:51
Red, Blue and Green Signs....HELP!!! ssjspawn Off-Season Events 3 17-11-2001 05:10
